Need some help.
#33
geez, i leave for a day and all of a sudden theres talk about my tools, dollies, and other randomness, lol
ok heres the update
fuel rail pressure with ignition on (not running) 37psi
i think this is low, but im not sure, anyone have numbers for this?
map sensor reference voltage - 4 should be 4 to 6
map sensor signal wire voltage no vacuum - 2.75 should be ~ 5
i couldnt test with vacuum due to no vacuum creation tool :P
TPS voltage - 1.5 (i think, it was hard to read) should be .5 to 1
TPS reference voltage - 4 should be ~ 5
TPS resistance (throttle closed) - eighty-bajillion should be 3k to 4k
TPS resistance (throttle full open) - eighty-bajillion and 7 should be 350
after reading i decided the problem could also be the IAC so heres that too
IAC voltage on both terminals - 12.5 should be 10.5
IAC resistance - 10.4 should be between 7 and 13
soooo basically, my TPS is screwed, least thats what it looks like to me
and i might need to swap my MAP sensor too on account of the low voltage reading
btw im working off the hanes manual for my limits and such ,idk if that changes anything
i also repaired my non-exhistant egr vacuum line, i do NOT have vacuum lines going to my ACV or my Air-BPV i have no idea where the heck those are, and my lines are broken for them, advice on that would be much appreciated.
i forgot, EGR sensor shows 5 volts, should be 5 and it also shows 4k ohms, it should be 5k, im not too sure that thats bad, but i can look into getting a new one if i still cant find the damn problem
ok heres the update
#34
If those readings are correct, and I have no reason to believe that they aren't, then yes, the TPS and MAP are your starting points.
When you get your TPS installed, try to shoot for .95v, even if you have to take a file to oblong the two bolt holes in the sensor. They'll tell you it's "non-adjustable", but you'll have better performance out of the new sensor if you make it adjustable.
See here:
http://goo.gl/0usT7
MAP is plug and play.
Go through all your vacuum lines and replace as necessary. I did all mine with rubber hoses a few months ago, so I've eliminated all possibility of vacuum line issues with my truck.
Use Motorcraft sensors where you can. Really, it makes a difference in quality!
See here:
http://goo.gl/0usT7
#35
#37
I bought 30' and 10' respectively, and it did both trucks. As the F-150 was a mis-match mess when I first got it anyway, I'm not sure if the hose sizes are right for you....it's just what worked for me.
Here is a great write-up that might be useful for some of you guys:
Replace Plastic Vacuum Hoses with Rubber - FSB Forums
(hope you don't mind a posting from an "other" site)
#39
right, thanks for that, i just finished replacing everything with rubber hose, guess what i found out!
apparently, the previous owner didnt like the smog rules, so they just cut and capped the entire smog pump/air byp/air control valve/crossover tube
none of it is connected, and none of it had the valves
sooooo i just capped off the vacuum hoses that were supposed to go to them and ill figure that part out later
got a new map sensor and new tps so now im going to install and run and see how it goes
wish me luck
wish me luck
#40
#41
#44
well it idles fine initially, basically, i started it, ran it for a bit, drove it up the street, and it died at a stop sign
soooo, i also replaced the idle air control valve, on account of the "it runs better WITH a vacuum leak"
i will go check all my voltages again, especially since NOW the ******* wont start at all, and it looks like i have less fuel pressure than before, possible fuel clog?
ill do a once over and see what comes up
btw if you want to make a bunch of cash, you should have invested stock in oreillys, if you have stock in oreillys, wait until i say my truck is running fine, then sell
#45
So, it dies once it warms up?
This could be caused by something being actuated by a temperature-actuated vacuum control device (the EGR comes to mind) but you said that's all been disconnected. *sigh*
The ignition modules are known to cause this kind of behavior when they're failing, too.
Pull your codes again........
