LMC Chrome Bed Side Tie Down Hooks? - Ford Truck Enthusiasts Forums
Old 09-22-2011, 08:34 PM
skibber's Avatar
skibber skibber is offline
skibber is gaining momentum as a positive member of FTE.
Has anyone installed LMC's Bed Side Chrome Tie Down Hooks? They come with a type of tube nut I've never seen before. How do they install?
Old 09-22-2011, 09:05 PM
79superduty 79superduty is offline
79superduty is starting off with a positive reputation.
I didnt install them, i just threw a bunch out and welded my holes closed . there like the ones for the mirrors,your gonnna have to drill a hole. then put in the bungs........
Old 09-23-2011, 04:46 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is offline
78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all78_f800crewcab4x4 is a name known to all
Bad idea to screw cheap china pot metal to your truck, leaves big holes/dents when you take them off. Absolutely ruins your bedsides. I used to screw crap to my bronco when i was 18, a few years later I regretted every single hole i drilled.
Use the stake pocket hole inserts from like Home Depot. NO drilling required and work better without ruining your truck, they fit right in your stake pockets
Old 09-23-2011, 09:30 AM
gregb gregb is offline
gregb is starting off with a positive reputation.
yeah, Im not a fan of the LMC tie downs. I think they ruin the whole look of the truck. I like the Home Depot stake pocket tie dows, that can be removed. or something custom welded inside the bed......made out of heavy stainless.
Old 09-23-2011, 11:32 AM
crazyeddie's Avatar
crazyeddie crazyeddie is offline
crazyeddie is starting off with a positive reputation.
My Trailer Special has tie-down hooks from the factory - they're much better material than LMC's crappy China re-pops. My friend put a set of LMC hooks on his truck and they turned green with oxidation within a month. At two months the chrome was pitting and falling off. It's not like he used them to tie anything down either.
Also, the factory bedside tie-down cleats have a heavy-steel backing plate that sandwitches the body-metal for strength when you actually crank down a load so you don't end up pulling a huge dent in the bedside.
Bed Tie down hook locations mbustillos 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-05-2016 10:12 PM
Tie down hooks Jarryd 1987 - 1996 F150 & Larger F-Series Trucks 5 07-01-2013 04:44 PM
Trying to find NOS chrome tie down hooks????? 1976HighBoy 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-15-2013 03:28 PM
Help installing new tailgate handle money pit 69 1967 - 1972 F-100 & Larger F-Series Trucks 7 04-24-2012 12:34 PM
no tie down hooks in box Reggie31 1999 to 2016 Super Duty 1 12-04-2010 10:34 AM
Tags
97, bed, bedside, chrome, downs, f250, ford, hook, hooks, install, lmc, side, sportrac, tie, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
