Which oils to use? - Ford Truck Enthusiasts Forums
Which oils to use?
Old 09-22-2011, 03:38 PM
49truck 49truck is offline
49truck is starting off with a positive reputation.
Which oils to use?
Are there any modern oils recommended to be used for the engine, gearbox, rear axle and steering box on my 1949 F3?
I have the oil specs from my original workshop manual but wondered whether developments in oil technology now gave more suited lubricants?
Thanks
Old 09-22-2011, 04:43 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
I'm a believer in modern synthetic oils for the transmission and rear-end. Lucas makes some GL-4 and GL-5 equivalent oils.
For the engine, there are several options. Modern oils have the zinc phosphates removed....your older flat tappet engine relies on that as an extreme pressure agent to protect the cam and lifters. Even the diesel oils have it removed now, so look for a racing oil that contains either Zinc Dithiophosphate or Zinc dialkyldithiophosphates (ZDDP). Valvoline makes one now and so does Brad Penn and Royal Purple (not all of the Royal Purple oils have added ZDDP, so watch out there). Another option is to buy some good oil and add a ZDDP additive. I found the Valvoline VR1 in both a synthetic oil and a straight petroleum oil...that seems to be the best deal, but stores seem to be stocking some unusual viscosity oils, so you may have to shop around or ask them to get a case for you if you want 30wt or 10w40.
Not sure on the steering box.
Dan
URGENT!! MOTOR OIL HELP!! waystro Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 04-27-2013 07:47 PM
Oil 15-40 motor oil Bvill01 1999 - 2003 7.3L Power Stroke Diesel 27 11-22-2012 04:45 PM
Where to install Oil Temp sensor vlietracer64 6.0L Power Stroke Diesel 5 11-03-2010 11:35 PM
What Oil/Oil Filter does everyone use? TexasTornado66 1961 - 1966 F-100 & Larger F-Series Trucks 32 10-03-2010 03:41 PM
Oil Change tomorrow Adam0331 1999 - 2003 7.3L Power Stroke Diesel 40 08-31-2008 10:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
