Hydroboost/Master Cylinder guidance - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-05-2012, 11:37 PM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.
I think we all might have a leaking(minor to major) hydo boost.
I just found out mine has been leaking a little for awhile now
I am going to replace as soon as I can
Old 07-25-2013, 01:37 PM
Grayson301 Grayson301 is offline
Grayson301 is starting off with a positive reputation.
Low/soft Pedal.. hydra boost systems
Doing a 2001 excursion ... aftermarket shows only one master cylinder.. motor craft shows two 1 with hyraboost BRMC26 and one with vacuum booster BRMC27. this is stroked differently .. try the correct master cylinder.
just found out the hard way
Old 07-17-2014, 01:19 PM
Mike F250's Avatar
Mike F250 Mike F250 is offline
Mike F250 is gaining momentum as a positive member of FTE.Mike F250 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Deuce45 View Post
Well I've seen quite a few posts on this exact issue, however nothing gets posted after a fix or people simply don't fix it.
I can't live with *****ty brakes any longer so I'm ordering both the Hydroboost and the Master cylinder, I can get both for under $300 and it looks super easy to install. I'll post by the middle of next week on results here goes nothing ........
Not trying to bust anyone's *****. But I'm researching soft breaks and thinking it's a master cylinder. I see no fix reported
Old 07-17-2014, 04:58 PM
spongecop's Avatar
spongecop spongecop is online now
Semper Fi
spongecop is gaining momentum as a positive member of FTE.
I was told by a member on here a while ago Ford had an issue with our master cylinders where the internal piston would over travel and force fluid past the cruise control cutoff sensor. Ford blamed the sensor for the fluid leak (and fires) but the real culprit was the MC. I have noticed on my truck the hotter the outside temps get the weaker the brakes and I get a progressively louder squeak/squish noise when the pedal is pressed. Hydroboost is also leaking a small amount.
So if the hydroboost only provides power brakes like a vacuum booster then the pressure and efficiency lies in the MC. If it is overtraveling causing leaks then maybe the pressures are off internally (+/-) causing poor performance. As soon as I have some money I am going to replace both units on my truck this summer.
Old 07-18-2014, 12:00 PM
05SuperFord 05SuperFord is offline
05SuperFord is starting off with a positive reputation.
Ok i'm guessing no one has heard anything about this. I'll chime in because i am about to put my 3RD set of rear brake calipers on my truck in the past year. Not sure why i keep going through them but i have the same symptoms and then eventually one of them will start dragging followed by the other. Just wondering if maybe this problem is related to what you guys are having going on?
Old 07-21-2014, 08:45 AM
Mike F250's Avatar
Quote:
Have you replaced the hoses? Not the lines, the hoses.
I'm happy to say mine was as simple as replacing the MC. I read through a few threads here on the brake issues and the one issue that couldn't get me past the MC is that with the truck not running, I could push the pedal slowly and it kept sinking.
Old 07-21-2014, 10:08 AM
Yeah i just replaced the right rear hose on Saturday in the rain brakes felt good for 50 miles and now there back to being inconsistent
Old 09-06-2014, 11:02 PM
sgarder sgarder is offline
sgarder is gaining momentum as a positive member of FTE.
Any update?
7.3 hydroboost failing? 20powerstroke02 1999 - 2003 7.3L Power Stroke Diesel 2 05-30-2016 10:08 AM
Hydroboost conversion problems... Please help!!! carguy29 1973 - 1979 F-100 & Larger F-Series Trucks 10 09-30-2015 05:05 AM
Sterling 10.25 Disc Conversion problems likeshills08 1987 - 1996 F150 & Larger F-Series Trucks 2 02-04-2015 04:11 PM
hydroboost leak question okie72 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-15-2014 10:35 PM
what would be the symptoms of a failing hydrobooster? powerstroker100 1999 to 2016 Super Duty 5 02-08-2012 11:14 PM
Tags
2004, 64l, boost, cylinder, diesel, duty, f250, find, ford, gasket, hydro, hydroboost, leak, master, super, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
