Aluminum Intake Question - Ford Truck Enthusiasts Forums
Old 09-22-2011, 08:59 AM
1951flatheaddave 1951flatheaddave is offline
1951flatheaddave is starting off with a positive reputation.
Hello all,
1951 F1 V8 flathead: Do you know of anyone that makes an aluminum intake for a single 2 barrel? I have seen them for 2 2 barrels or a single 4 barrel but I really dont want to run 2 carbs nor do I think the motor needs a 4 barrel. I am not looking to boost horsepower greatly, just looking for a nice looking intake.
If you know of one or have one for sale let me know. Thanks, Dave
Old 09-22-2011, 09:43 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I have this triple Offenhauser intake that I'm contemplating selling. Since the picture was taken, it has been cleaned up and looks brand new. Has a small break on the generator pulley bracket section, but won't affect the mounting and operation of the pulley.
Not sure if it's a repop or not. I don't see a date stamped on it, which repops usually have.
You can also try Red's Headers, Offenhauser Intake Manifolds. Seems like you can order what you need from them. Also check with Speedway Motors and Summit Racing.
Old 09-22-2011, 09:48 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Canadian engines had stock, aluminum manifolds. You see them on eBay pretty frequently. Exactly the same as cast iron except about 20 lbs lighter. Be very sure the generator mount area is intact. They are usually going for less than $50.
Old 09-22-2011, 11:54 AM
Thanks Ross, I am liking the idea of being 20 lbs lighter but still being able to retain the stock carb. I will check out ebay when I get hom, its blocked here at work. Thank goodness this site isnt!!!
Old 09-22-2011, 12:52 PM
Nothing on Ebay right now, If I did go with the 4 barrel intake how small of a carb would I need to run?
Old 09-22-2011, 03:03 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is online now
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Usually a 390 CFM for a stock motor is about as low as you can get - Keep a good tune on the motor and the right? fuel pressure and it should work OK.
Old 09-22-2011, 03:25 PM
Dick, I was hoping you had an intake you would sell me on sunday! See you around noon. Dave
1979 FORD F-250 INTAKE MANIFOLD AND CARB QUESTION ryanparhaniemi 1973 - 1979 F-100 & Larger F-Series Trucks 20 11-26-2016 09:41 PM
390 and 360 Shawnboylk 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-25-2016 07:20 PM
360FE intake tstewart78 1967 - 1972 F-100 & Larger F-Series Trucks 5 02-22-2016 03:13 AM
engine id 69issofine 1967 - 1972 F-100 & Larger F-Series Trucks 2 10-21-2014 06:40 PM
Intake Manifold 80 f-150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-05-2011 11:47 PM
Tags
2002, 54, aluminium, aluminum, barrel, breaks, f250, flathead, ford, intake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
