Alternative to ruining your PCM with an EDGE programmer - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-22-2011, 09:53 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Exclamation Alternative to ruining your PCM with an EDGE programmer
Let me start by saying that I have no personal agenda against Edge and nothing to gain from anyone buying anyone else's tunes for their truck. In fact as of now, I don't have tunes on my truck at all. That being said I feel that a bit of a PSA is in order to warn folks of the potential dangers of using an Edge programmer on their 7.3 PSD powered truck (outside the 7.3 PSD you can draw your own conclusions about Edge products).
The bottom line is that while there may be many drivers who have Edge programmers on their trucks and have had very good success with them, there are also many who have ruined their PCM by using an Edge programmer, causing them to need to replace or at least have their PCM re-flashed by the dealer (usually at a cost of a couple hundred dollars).
The issue is that the Edge programmer is just that....a programmer. It uses your OBD port to erase the stock program in the PCM and then re-write a new program into it. That is how you can unplug the edge and put it back into your toolbox and continue to drive the truck on Edge tunes. While this may work for some, for others, the process of erasing the programming and re-writing it can corrupt the data on the PCM causing it to fail to function all together, which generally means you cannot connect the Edge programmer to it again to dump your stock program back into it.
Fear not! There is a (better) alternative to this method of programming. It is called a performance chip. It plugs into the PCM via an edge connector built into the PCM from the factory. These chips stay on the PCM and interpret data that is going through the PCM to allow the truck to run better (and in the case of custom tunes -- much better).
There are a variety of places you can get these chips, but they really are broken down into two categories. TS style and Proprietary style chips. The TS style chips are all based on the design that TS Performance uses on their chips that includes a rotary **** that allows you to toggle to different tunes (usually up to 6 tunes) on the fly. Worth noting of course is that to my knowledge TS performance does not offer custom tunes on their chips, meaning they are all "canned" tunes (more on this in a moment). There are a veritable cornucopia, an plethora even, of other tuners who will take that TS style chip and for a few of your hard earned dollars custom tune a set of programs (of your choice) to that chip so that you can get the most out of your truck. There are lots of choices out there for this, but some of the more popular tuners are:
Power Hungry Performance (aka PHP)
Total Diesel Performance (aka Tony Wildman)
Gearhead Automotive Performance
Brian's Truck Shop (aka BTS also makers of some of the best transmissions you can buy for your truck -- think unconditional lifetime warranty!!)
Beans Diesel Performance (aka Beans or BDP)
Swamps Diesel and
Tyrant Diesel
These guys all can and will use the same TS style chip and custom tune to your specifications. Some will even offer free -re-burns (change your tunes for free) if need be.
The other group are tuners who use a more proprietary type of tuner and the most popular of these is
DP Tuner
DP uses a different style chip and offers a cool digital switcher that can be mounted in a gauge pod.
The other thing to consider is whether you want "canned" tunes, custom tunes, or live tunes. A canned tune is a tune generated by the chip manufacturer as a one-size-fits-all approach to tuning and burned to their chip for mass consumption. This will be better than stock but not as good as the next option which is Custom Tunes. Custom tunes are the result of hours of research and years of experience by the tuner of your choice. You tell them about what you have or plan to do to your truck and they burn a chip to your specifications that is custom tailored to work with your existing or future performance modifications. This generally costs a bit more than a canned tune, but it is money well spent. The highest level of tuning is what is called "live tuning". this pretty much means that you drive your truck to the tuner's shop and they put their gear on your truck and generate tunes that are custom built to your specific truck's performance. They can tweak small things as they tune to squeeze every last ounce of performance out of your setup and give you exactly what you want. This of course costs more than custom tunes and requires you to do some traveling, but you can be assured of the highest level of service and performance.
Finally, you need to ask yourself something, "why do I want a tunes"? Well usually the answer to this is simply MORE POWER (I can almost hear Tim "the Tool Man" Taylor barking in the background). But adding a tune to your truck can change everything from throttle response, idle speed, transmission shift points, shift firmness, smoke output, etc. The tuner can also significantly improve your fuel economy (provided you can keep your boot out of the smoke pedal ).
Well there you have it. A more complicated, slightly more expensive, but much more reliable and stable way of tuning your truck's drive train.
You have been forewarned. Good luck with the decision!
P.S. Maybe the mods could make this PSA a sticky? Hint, Hint....
P.P.S. I am open to correction if I have made any incorrect statements, but I don't intend for this to devolve into a debate about whose tunes are better.
Old 09-22-2011, 10:41 AM
f350rebel7788's Avatar
f350rebel7788 f350rebel7788 is offline
Sergeant, USMC
f350rebel7788 is starting off with a positive reputation.
Just FWIW, DP tuner now carries the f8 chip, which has the rotary switch like all the others. If I'm to understand it right, it's the same style as all the other tuners use, so it can be used for any and all tnes.
Old 09-22-2011, 10:54 AM
My understanding is that while the F8 does use a rotary ****, other tuners aren't on board yet with dumping their tunes into the F8...
Old 09-22-2011, 10:57 AM
Sergeant, USMC
Ahhh, gotcha! So the f8 may support their tunes, but the tuner may not want to tune em? Or they can't tune em?
Old 09-22-2011, 10:59 AM
My understanding is that the F8 is similar in desing to the TS chip, but different enough (and DP Makes it) so other tuners are hesitant to get on board with it. Not sure of the particulars why though....
Old 09-22-2011, 11:04 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Quote:
Unfortunately, Jody is the only one who can flash these, its a different chip.
Jody's chips give him a few more options on tuning with chips, specially his more advanced chip.
Thats one of the reasons other people cannot flash them. He's spent big bucks trying to tune further than the other guys.
This being said does not mean the other tunes are bad tuners.
As well to add. Jody can also re-flash your bad PCM or fix worn out contacts as well as part of his services.
Old 09-22-2011, 11:08 AM
Sergeant, USMC
Thank you for clarifying that one!
Old 09-22-2011, 11:09 AM
Talyn's Avatar
Rep Jail. =*(
Great post though!
Talyn's Avatar
I sent a message to Jody to jump in here and clarify. I wanted to make sure my info on his product was 100%.
Old 09-22-2011, 11:19 AM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Great info tried to rep you but you know how that goes.
Somebody rep this man.
Old 09-22-2011, 11:49 AM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Well done Nate!
Old 09-22-2011, 12:07 PM
BuckHammer's Avatar
BuckHammer BuckHammer is offline
BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.
This warning against using edge programmers ought to be stickied.
Old 09-22-2011, 12:51 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Same here.
Old 09-22-2011, 12:57 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
+1 on the sticky. This is the most informative thread I've seen yet, on ALL the truck sites, that clarifies programmers vs chips vs tuners. Puts it ALL together.
Edit - reps sent.
Old 09-22-2011, 02:14 PM
Talyn's Avatar
just for some fun
haha
easy modifications for my work truck, for under $1,000-1,500 greenstar 1999 - 2003 7.3L Power Stroke Diesel 7 12-15-2013 08:52 AM
Stacking a DFUSER AIC w/ a TS 6 pos chip or DP Tuner F6? xbox73 1999 - 2003 7.3L Power Stroke Diesel 6 05-20-2012 11:36 AM
Remote Custom Tuning (Iterative) xbox73 1999 - 2003 7.3L Power Stroke Diesel 7 05-02-2012 01:16 PM
Chip and Tuner Frequently Asked Questions - READ BEFORE POSTING HERE FTE Ken Computer Chips & Tuners 0 01-25-2005 11:58 AM
Tags
bad, chip, conect, custom, edge, excursion, ford, pcm, programer, programmer, repair, site, troubleshooting, tune, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
