Sloppy Hood Hinges on 49
Old 09-22-2011, 08:22 AM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
How can I remove the slack in the hood hinge arms or bushings.
Thanks
Old 09-22-2011, 09:35 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
I don't think that you can. You'd have to replace the springs.
Old 09-22-2011, 01:03 PM
brain75's Avatar
brain75
brain75 is offline
The PO in mine did something that seemed to work a little bit, instead of shoulder bolts, he put in the next size bigger and longer bolt with two nuts jambed against each other (if you cranked the nut to the bolt then there is too much stress on the open close mechanism. I'm not at the shop, so can't look - just guessing but the original 3/8 shoulder bolt is in a 7/16 hole (either that or mine was just worn in a near perfect 7/16 circle) - so upping to 7/16 took the slop out there.
But that is just guessing a bit - what is causing your slop, the springs worn / broken, are you getting slop on the top bolt, bottom bolt, is the firewal flexing and causing slop on the bottom half (you said bushing so threw out the above).
Old 09-22-2011, 01:13 PM
Doc's Avatar
Doc
Doc is online now
I think he's talking about the permanent pins that hold the arms together. Not the springs or the bolts going through the cab itself. I have heard of people taking those things off and hammering the crap out of the backside of the pins in order to make them flatten out and fill up the worn holes better. BUT, if you go too far, you might just lock up your mechanism. I would be afraid to do it, but I have heard of some folks doing it that way.
Old 09-22-2011, 01:20 PM
brain75's Avatar
brain75
brain75 is offline
Ah, guess the PO put bolts in mine (hence my saying "lower bolts") - didn't realize they were pins... guess I just never really looked.
And I guess what the PO did in my case might be 1 way to solve the problem
Old 09-22-2011, 11:59 PM
51PanelMan's Avatar
51PanelMan
I have several used hood hinges in case you decide to change them out.
Old 09-23-2011, 07:58 AM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
Thanks for the ideas and offer now I have a few things to try.
Allan
Old 09-23-2011, 09:35 AM
F1 48 Ford's Avatar
F1 48 Ford
F1 48 Ford is offline
I used a hydraulic press on my 48 hinges. It took all the slop out out of them.Just go easy. Dean
hooler1
09-09-2017 09:41 AM
Pappys53
06-30-2012 12:36 PM
wagonerkl
13
03-24-2009 08:15 PM
imlowr2
07-06-2005 08:07 PM
Rocking M
07-03-2003 03:58 PM
Quick Reply: Sloppy Hood Hinges on 49
