Want to install AUX/Backup lights
Ah, another electrical project! The upfitter switches have relays in them, so all you need to do is run an approriate sized wire from the correct relay (Up#1 is 25 amps, Up#2 is 25 amps, Up#3 is 10 amps and Up#4 is 15A) to your lights.
If you want to run them off of the reverse circuit, you will need to stick a relay in the back and run a power line to the back and connect it to terminal 30. Obviously your lights would replace the backup alarm on terminals 85 & 87. And your reverse light red wire (+) would go to terminal 86. When you put the truck in reverse, the relay would kick the power on 30 to the lights. Here is the thread with a picture: https://www.ford-trucks.com/forums/1...me-help-5.html
Also, Beezil provides the part numbers in that thread for the Hella relays. I can personally testify that these relays are top notch and are made for outside usage.
