Changed HPOP Oil truck won't start
my truck was running perfect, needed an oil change.
drained the oil, replaced filter, new 14 quarts started right up.
pulled a quart from the HPOP, installed until over flowed, started right up.
pulled a second quart from the HPOP, installed until over flowed, started right up.
pulled a third quart from the HPOP, installed until over flowed, started right up and ran for 15 second.
turns over beautifully, won't catch. HPOP is full.
I believe I am having the same problem. Any suggustions?
Thanks in advance!
TRUCK:
1997 OBD F250 7.3l stock everything 230k
Thanks in advance!
TRUCK:
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums Here is a link to the page for your engine, probably better to ask there for expert opinion.
cmmeur01
28
03-31-2013 01:59 PM
dizzyfingers03
03-31-2013 08:14 AM
