R&R, hub needle bearings, axle u joints, axle seal
Dust seals, are not necessarily needed, you can pull the axle out of the tube, but there is one seal in each end of the axle tube outboard towards the tires. And then there are 2 seals inside each inboard side of the axle tube, pumpkin area, hopefully they will be fine. There are also seals where the axle goes through the hub assembly/knuckle but those should be fine too.
Honestly based on your issue, the needle bearings are probably all you need. but the axle joints wont hurt. Good luck, take pics and show all your work!
well ill take your advice then, I'll just start with the needle bearings and if it doesnt fix then I pull the hubs again and try the u joints, I will try to take some nice quality pictures to show, I'll pick up the needle bearings tomorrow from napa.
I plan on removing the hub from the knuckle by just hitting it with a sledge hammer, I dont have any fancy 3 jaw pullers to hook up
ill pick up some extra hub studs just in case and some of the axle washers that fit behind the snap ring just incase they disinigrated
It's actually easier to separate the hub with an impact hammer where the hub mates with the knuckle. Just make sure you smooth it out after you get them apart so there isn't a gap when you reassemble it. The needle bearings are really easy to swap out, and the knuckle seal is a mother. It's also expensive and easy to mess up, it's a super seal style seal so it has to seal to the axle and the hub. I had to use a short piece of 4" exhaust pipe to get mine seated a couple of weeks ago when I replaced my hub locks and bearings.
I was just driving the truck and when turning the wheel while driving it seems to get "locked" in the turning position its in, this results in me yanking the wheel back straight, it feels like something in the front end is binding, I wish I could afford to just replace everything but I cannot, its scary to drive my own truck
I had that symptom once on my 1994 Explorer and it was the axle u-joints so maybe the same thing on yours.
Lots of info on ball joints, needle bearings, etc here:
2004 F250 Ball Joint Replacement
so I'm going to try and leave the pumpkin seal, but I will have to buy a inner dust seal and outer dust seal? for the axle shaft right or is it called a knuckle seal
Alrighty I think I got it now, so I'll need one knuckle and dust seal
when you did your ball joints and replaced the big seal in the pumpkin, did you have to remove the pumpkin like they talk about in this thread?
https://www.ford-trucks.com/forums/92...placement.html
I think in your writeup you say you were able to pry it out with a screw driver or something?
Wheel Bearing:
Ford # C6tZ-3123-A $9.30 each
NAPA # B2110 $6.42 each
Small Knuckle Seal or "Dust Seal"
Ford # F81Z-1S175-HCA $15.46 each
NAPA # 21918 $8.99 each
National #710413 $7.84 each
Large Knuckle Seal or "Oil Seal" (pressed on with special tool)
Ford #F81Z-3254-CB $26.54 each
NAPA N/A N/A
Hub Assembly Seal (small yellow seal)
Ford #F81Z-4A322-AA $3.48 each
NAPA N/A N/A
Upper Ball Joint
NAPA #260-1248 $30.44 each
Lower Ball Joint
NAPA #260-1395 $48.69 each
Auto-Lock Hub
Ford #1C3Z-3B396-CA $279.00 each
NAPA N/A N/A
NAPA N/A N/A
Upper Ball Joint
Lower Ball Joint
Auto-Lock Hub
Your problem does not sound like the hub axle bearings, sounds more like the U-Joints. If they are shot you should be able to tell by holding one side of the axle and trying to move the other up and down and side to side. If there is play the kardan joint (the style of U-Joint on the front axle) is ready to be replaced. They also suck to replace. Are your hub locks working okay?
#30
