electric fuel pump recommendation? - Ford Truck Enthusiasts Forums
Old 09-21-2011, 08:02 PM
r_reed's Avatar
r_reed r_reed is offline
r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.
i am using an electric fuel pump on my 239 flatmotor, converted to 12v. neg ground. i like having the electric fuel pump but it is quite noise. at idle it is louder than the engine. are there pumps out there that are not so loud? thanks, dick r.
Old 09-21-2011, 08:20 PM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
Dick, you need a louder exhaust system. Seriously, I am using a Holley standard pressure red electric pump. Seems fairly quiet. It puts out 7 psi and does not require a pressure regulator. I have it mounted on rubber isolator blocks so it does not vibrate.
Old 09-21-2011, 08:51 PM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
my pump is the round style with a rubber mounted clamp that keep's it fairly quiet ..is yours frame mounted or on the firewall?? frame mount is much better ..and I run a regulator to knock the pressure to 2.5 lb..
Old 09-21-2011, 10:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I think I have the same one as Ken, Auto Zone #E8016S. Besides the rubber clamp around it, it is on a cantilever bracket that is mounted on rubber shock biscuits, and with rubber hose segments in/out. It makes noise until it builds pressure, then is very quiet.
Old 09-21-2011, 11:05 PM
kenjh's Avatar
you know it will be quieter when you get the door's and front fenders on ....
Old 09-22-2011, 06:22 AM
r_reed's Avatar
i do have the doors, fenders, etc. on. i'm going to try the rubber block mount. i'm going to do one similar to the 3 to 2 metal master cyl mount. i'll blind bolt the pump to a 1/2" rubber block, then i'll do 2 add't bolts to bolt the block to frame.
Old 09-22-2011, 09:14 AM
kenjh's Avatar
I was looking at your ..avitar? and saw the project ..and had to make a comment..look's like you have gotten a lot done..verry nice.
Old 09-22-2011, 11:17 AM
r_reed's Avatar
ken, the avatar was the state of the f1 on april 1, we than had to take a break and fix my brother in laws '49 ch**y pickup that got rearended last sept after just two months on the road. we work 2 days a week, we started back on the f1 memorial day weekend and finished last sunday. i'm packing my summer driving into two months of fall driving. thanks for the pos comments. dick r
Old 09-22-2011, 05:58 PM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Cut out a section of old tire to use for an isolator...works great and the price is right. Al Gore will love you for it too...very GREEN.
Fuel Help: Mechanical to Electric Fuel Pump rcfreed 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-26-2015 01:20 AM
Electric Fuel Pump lift pump rodymartin Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 02-23-2014 10:42 PM
Electric Vs Manual fuel pump? OARfan 1973 - 1979 F-100 & Larger F-Series Trucks 6 12-22-2010 12:32 PM
How should I wire my electric fuel pump? 1973 - 1979 F-100 & Larger F-Series Trucks 10 02-07-2010 12:00 PM
Electric Fuel Pump 79 Bronco 79FordBlake 1978 - 1996 Big Bronco 7 08-08-2008 03:45 PM
Tags
duty, electric, fuel, pump, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
