Changing read end gears fron 355 to 410 - Ford Truck Enthusiasts Forums
Old 09-21-2011, 07:59 PM
walbert52 walbert52 is offline
walbert52 is starting off with a positive reputation.
Hi everyone, I need some advice I just finished rebuilding my 92 F-250 460 it's two drive and has a rebuild E4OD trans, with 355 gears, runs fantastic.. I am thinging of changing the rearend to 410 gears because I will be pulling my 6800 lb camper through the mountains out west and some or 9000 to 11000 feet. The motor is stock with .030 pistons, is this a good choice and it there anything I need to change on the tranny for the speedometer, also is the computer good to go as is???? I will change to whole rearend not just the gears.. Is that the way to go also????? I help and advice or welcome... Thaks Wade
Old 09-21-2011, 10:06 PM
rwdfan's Avatar
rwdfan rwdfan is offline
rwdfan is starting off with a positive reputation.
Wade, a change to 4.10 gears would be a good choice. But you will want to be sure you are using the stock tire size. That 460 produces a lot of its power in the lower rpm band, so you dont want to get the RPMS too high, like you would on a v10. Towing at that high of an elevation might present some problems. I would focus on the truck being able to breathe well, perhaps at least a K+N flat filter to replace the OEM filter. Maybe someone else will chime in for ideas on towing at higher elevations. I would normally say a performance tuner if it wasnt an OBD1 vehicle. I don't think the tuners for these older trucks do much good at all. I would also install a transmission cooler and a transmission temp gauge to keep an eye on things while towing. These ford transmissions have some problems (prob why you had to rebuild) and you want to be nice to them. Also, changing all of your fluids to synthetic couldn't hurt.
Old 09-21-2011, 10:35 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
Changing rear end gears will not affect your speedometer. I went from 3:31s to 4:10s and had no change at all. your speed is determined before the rear axle, changing things there will only affect how fast you get up to certain speeds. If you can find a full axle for cheap, id say go for it, its much easier and safer to go that route, as long as the new gears were installed by the factory. Ive run into problems w/ shops setting up gears that dont know what theyre doing.
Old 09-21-2011, 11:24 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
I'm with Blue Rebel on this one. Changing the gear ratio will not affect a truck's speedometer that uses the VSS sensor on the rear end and a PSOM. The VSS is triggered by the tone ring on the ring gear. Changing the gear itself has no bearing on the number of pulses per mile from said tone ring. Tire diameter will, not gear ratio.
BTW...1992 was the first year Ford used the electronic speed/odometer.
Old 09-21-2011, 11:29 PM
rwdfan's Avatar
I stand corrected on the speedometer gear cable! I'm also with Blue Rebel on the comment with the rear end, changing out the whole rear end rather than trying to change the gears themselves is a better idea. Especially if you plan to do it yourself, not having the knowledge of how to set-up your gears would be disastrous. Although, if you wanted to install a locker or any kind of aftermarket differential, this would be the time to do it, but have a professional rebuild the rear end with the 4.10 gears and a selectable locker.
Old 09-22-2011, 10:25 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
definatly 4.10's with a limited slip. what exhaust upgrades have you done? i would also focus on this part to better help that thing get over the mountains.
Old 09-22-2011, 07:21 PM
I would like to get the banks headers and stainless exhaust, but in the cards now, also the trans command by banks too... Ijust found out that the rearend is a 10.25 not 8.8 according to the tag on cover...Will the computer throw a code because of the rearend change???? Thanks everyone Wade
Old 09-22-2011, 07:28 PM
REAREND CHANGE FROM 355 TO 410
I checked out the tag on the cover and it's a 10.25 not 8.8... Will the CEL come on after the change???. Is there away to tell for sure that I'm getting the right unit from the boneyard, just in case the tag is removed??? All help would be great...Thanks again Wade
Old 09-22-2011, 07:54 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
No the CEL won't come on if you change gears.
Old 09-22-2011, 07:55 PM
Edgethis's Avatar
Quote:
If it 's a rear axle and it has8 lugs and is on our body style thats the one.
Old 09-24-2011, 09:58 PM
Drive shaft problems
Thank you to everyone that posted help on replacing read end... I got the 410 rear end unit installed, it was from a 95 F-250 and in great shape and perfect fit... NOW THE PROBLEM IS THE U JOINTS DONT FIT THE PINION YOKE THE BEARING CAPS OR TO BIG (1.188 INCH OD). THE PINION YOKE TAKES A SMALLER BEARING CAP (1.125 INCH OD)... DOES ANYONE MAKE A U JOINT WITH TWO DIFFERENT SIZE BEARING CAPS???????????? PLEASE HELP!!!!!!!!
Old 09-24-2011, 10:00 PM
Edgethis's Avatar
Thank you to everyone that posted hel on replacing read end... I got the 410 rear end unit installed, it was from a 95 and in great shape and perfect fit... NOW THE PROBLEM IS THE U JOINTS DONT FIT THE PINION YOKE THE BEARING CAPS OR TO BIG (1.188 INCH OD). THE PINION YOKE TAKES A SMALLER BEARING CAP (1.125 INCH OD)... DOES ANYONE MAKE A U JOINT WITH TWO DIFFERENT SIZE BEARING CAPS???????????? PLEASE HELP!!!!!!!!
Yes, they are called ******* joints in shop shops. You might be better to get a new pinion. As ******* joints never seemed to have the same strength as a standard joint.
Old 09-25-2011, 05:33 AM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Why would a thicker cap on two sides make the cross weaker???
Are both sides 3 5/8" between the clips or bosses?
if so, you're looking for a 1350-1330F conversion U-joint.
Spicer 5-1313X
Neapco 2-4953
Here's a handy table; http://www.drive-lines.com/ujs/uj_conversion.php
Old 09-25-2011, 02:08 PM
rla2005's Avatar
The factory u-joint on my 1992 F350 standard cab w/E4OD transmission uses two different size caps. Ford lists about a bajillion different combination of engine/trans/drive/wheelbase length that seem to have their own unique u-joint size. It's a real b**ch to find the right one even if everything is like it was from the factory.
Old 09-25-2011, 03:10 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Try NAPA or carquest for an oddball ujoint, the people at the discount places (Autozone, Advance...) usually have a hard time with anything that strays from factory... You gotta get the book out to find the right one.
ECM Programmer Technicians / Hobbyist Atc210 Excursion - King of SUVs 4 11-04-2016 03:28 PM
1995 f150 rear end options 1993_f350_2013 1987 - 1996 F150 & Larger F-Series Trucks 2 11-24-2014 12:28 AM
E350 rearend gear change moosey78 Modular V10 (6.8l) 2 10-28-2013 12:06 PM
460 UPGRADES walbert52 1987 - 1996 F150 & Larger F-Series Trucks 2 01-14-2013 11:07 AM
351w build 410 Performance & General Engine Building 31 06-27-2009 12:21 AM
Tags
1996, 2003, 355, change, duty, f150, f350, ford, gear, gears, replacing, ring, size, super, tire, tone
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
