In wich category do you search for it? I tried RABS valve and nothing found.
I find it by picking, ford, 1996, f250, then look for the catagory/drop down for brakes. Let me know if you still can't find it. I believe it is called a "ABS modulator valve".
I believe that would be the correct name for it.
RABS is really the name for the system as a whole.
Thanks for all the info. guys on the parts to order, I am going to order the RABS unit from Rock Auto, but in the mean time plumb the line strait to the back so I can at least get the truck on the road and I can splice the line later to add the RABS unit. Thanks again for the great info.
