99 3.0 runs really rough. - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-21-2011, 05:50 PM
Gary E's Avatar
Gary E Gary E is offline
Gary E is gaining momentum as a positive member of FTE.
stumped on this one. its had the 401 code for quite awhile without issue but now it is running really rough and is very low on power.
we replaced the spark plugs which were pretty much completely worn out electrodes worn down to the porcelin and it ran great for a week then the stumbling came back. We replaced the egr and dpfe and the codes are not reappearing so far but it still runs terribly.
When I checked the fp the guage only showed 25 psi. we replaced the fuel filter and now fuel pressure is 55psi. but it still runs really rough. No codes.
What do we do next?
Old 09-21-2011, 06:26 PM
Midwest Dually's Avatar
Midwest Dually Midwest Dually is offline
Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.
Sounds like a clogged up EGR valve.
Old 09-21-2011, 06:45 PM
Gary E's Avatar
egr valve is new and I checked the port in the manifold
Old 09-21-2011, 07:17 PM
Dutter's Avatar
Dutter Dutter is offline
Dutter is starting off with a positive reputation.
Is it stalling or just reving ruff. If its stalling id check the IAC valve and id check if u got spark to all cylinders too
Old 09-21-2011, 07:28 PM
Gary E's Avatar
running really rough, not stalling I wonder if my injectors are clogged or maybe the coil pack is bad? We did not replace the plug wires when we did the spark plugs, do they really go bad? also wouldn't a bad plug wire or coil pack throw a code of some sort?
Old 09-21-2011, 08:11 PM
Phinxter's Avatar
Phinxter Phinxter is offline
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
Quote:
yeah they really go bad, really. If they never went bad we would never need to replace them. It might not set any codes either.
Old 09-21-2011, 08:12 PM
Dutter's Avatar
Yep clogged injector will deffenitly cause it to run ruff. So id clean those out and sea foam the intake as well, my ranger ran alot soother after i ran sea foam. And yeah plug wires can go bad and same with the coil pack. But test each plug for spark and that will well u if its that or not. And i dont think it would thro a code unless it was the coil pack. But just test for spark and see whats what
Old 09-22-2011, 02:16 PM
Gary E's Avatar
ok put it on the fancy $1300 scanner from snap on and it basically said the computer was not able to complete its self diagnostic test. what does that mean? bad computer?
Old 09-22-2011, 07:10 PM
Gary E's Avatar
I pulled off the plug wires one at a time and ran it and I can't tell that any one cyl is worse than another. This thing is killing me it has to be running by monday....
Old 09-22-2011, 08:27 PM
Dutter's Avatar
hhhmmm ok try cleaning the injectors then
Old 09-22-2011, 08:50 PM
Gary E's Avatar
I need a cliff to drive this thing off! I had one plug that was arcing out to the head, (i could see sparks around the plug) so I moved it to the next cyl and it did the same thing in that hole so I replaced the plug and its better but still not right. argh I guess I will replace all the plugs again and swap out wires, then go to coil. I will also put some injector cleaner in too, I guess seafoam brand.
Old 09-22-2011, 10:01 PM
Dutter's Avatar
Ok hold up. Iv had the best luck with the lucas EFI cleaner. That will clean ur injectors. The Sea foam will clean out the valves, intake and tops of the pistons not so much the injectors but idk it might. But if the injectors are so dirty that there maken the motor run ruff id take them out and clean them with BRAKE cleaner. because the EFI cleaner works really good but over time like on tank of gas. It sounds like ur needed to fix it quick
Old 09-22-2011, 10:38 PM
jndinmo's Avatar
jndinmo jndinmo is offline
jndinmo is starting off with a positive reputation.
If it's arcing to the head it's the spark plug wire (boot) not the plug, and that will make it run bad every time. You had better quit throwing parts at that thing and go get a new set of wires, and if it does it very long it can burn the coil up.
Need Some Direction JonathanN 1994.5 - 1997 7.3L Power Stroke Diesel 6 03-14-2012 03:48 PM
Bad fuel economy, HWY and CITY, pulling hair out! hivoltj 2004 - 2008 F150 6 03-08-2012 09:00 PM
2000 ranger 3.0 running rough with CEL and codes Help Please! magneto259 Ranger & B-Series 2 11-20-2009 05:44 AM
Need Help!!! '03 6.0, bad fuel pump, now no start. vlietracer64 6.0L Power Stroke Diesel 3 01-19-2009 11:39 PM
eec-VI- code 179 ughhh! tome Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 01-20-2004 09:35 PM
Tags
1994, 30, 99, codes, ford, poorly, ranger, rough, run, running, runs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
