1951 V8 Flathead Fuel Pump Block Off
Hello, My 1951 F1 V8 flathead has an electric fuel pump connected right to the carb. The mechanical pump is still there but just not hooked up. I ordered a block off plate for the intake manifold and someone told me the intake needs removed and the fuel pump pushrod hole needs a plug put in or the engine would lose a tremendous amount of oil pressure. Others have said they have blocked the fuel pump off and left the pushrod hole alone and have had no problems.
Thoughts?
Thanks!!!
Thoughts?
Thanks!!!
Did you find a definitive answer in any of that, Dick?! Personally, I cut the old pushrod, welded a nut on top, and dropped it in, because at the time I was so confused by the discussions on the Flathead Forum. It's been bantered around back and forth so many times that I lean towards the real experts (Bruse Lancaster, Ol Ron, etc) not these guys who say an old-timer "who must know" told them such-and-such. The differences between 59 and 8BA are frequently lost in those discussions; on the early engine the breather is right there, on the 8BA it isn't.
Dave, you can't go wrong leaving a chunk of the rod in there, enough to fill the bushing but not so much it touches the cam lobe, with something permanent on top to keep it there. But there are plenty of them running with nothing in the hole. Watch your oil pressure and judge for yourself.
Sorry to bring up an old thread, but I just bought a 52 ford f1. Previous owner put in an electric fuel pump and left the mechanic fuel pump mounted to the intake, but disconnected except for the vacuum line. Should I at least disconnect the vacuum line to it? If I do, and I do a PCV on this, can I plug the PCV into that vacuum port? Sorry for my ignorance, I am new to working on these vehicles and want to learn!!
Thanks!
Thanks!
Thanks Ross. I am glad that we can search for answers on this forum. I had read about a bushing plug but I have never had a problem without it on my 8BA.
When I first went to an electric pump, I cut the old pushrod and welded a heavy nut on the top, dropped it in the bushing. It didn't touch the cam eccentric. Two years later I had occassion to pull the manifold and found the plug laying in the valley! I put it back in, and started the engine with the blanking cover off -- the plug shot right out of the bushing! I'd been driving it like that with no ill effects or noticeable change in OP. At the time I had a lathe so I took a long 1/2" bolt and made a plug that came to just under the blanking plate, so it couldn't pop out. Overkill but always looking for a lathe project!
lbrauer
08-08-2011 02:18 PM
