1951 V8 Flathead Fuel Pump Block Off - Ford Truck Enthusiasts Forums
Old 09-21-2011, 02:58 PM
1951flatheaddave 1951flatheaddave is offline
1951flatheaddave is starting off with a positive reputation.
Hello, My 1951 F1 V8 flathead has an electric fuel pump connected right to the carb. The mechanical pump is still there but just not hooked up. I ordered a block off plate for the intake manifold and someone told me the intake needs removed and the fuel pump pushrod hole needs a plug put in or the engine would lose a tremendous amount of oil pressure. Others have said they have blocked the fuel pump off and left the pushrod hole alone and have had no problems.
Thoughts?
Thanks!!!
Old 09-21-2011, 03:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
No, nope, uh-uh. Pull the rod out the fuel pump hole and put the block-off plate on. You're done. 59-series engines (pre-'48) needed the bushing for the pushrod plugged or there would be a lose of oil pressure. 8BA/8RT engines do not.
Old 09-21-2011, 03:17 PM
Thank you!!! I really wasnt looking forward to pulling the intake off!
Old 09-21-2011, 05:39 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Old 09-21-2011, 06:01 PM
ALBUQ F-1's Avatar
postin' fool
Did you find a definitive answer in any of that, Dick?! Personally, I cut the old pushrod, welded a nut on top, and dropped it in, because at the time I was so confused by the discussions on the Flathead Forum. It's been bantered around back and forth so many times that I lean towards the real experts (Bruse Lancaster, Ol Ron, etc) not these guys who say an old-timer "who must know" told them such-and-such. The differences between 59 and 8BA are frequently lost in those discussions; on the early engine the breather is right there, on the 8BA it isn't.
Dave, you can't go wrong leaving a chunk of the rod in there, enough to fill the bushing but not so much it touches the cam lobe, with something permanent on top to keep it there. But there are plenty of them running with nothing in the hole. Watch your oil pressure and judge for yourself.
Old 09-21-2011, 07:07 PM
4tl8ford's Avatar
I always plug them cause all the Ex-Sperts confuse me - I use wooden dowels mostly so I don't damage the bushing
Old 09-21-2011, 08:20 PM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I used a piece of dowel......I was told that oil mist would would escape if left open. No biggie, just a peace of mind thing. Either way, you won't lose oil pressure.
Old 07-07-2015, 09:11 PM
52flatheadf1's Avatar
52flatheadf1 52flatheadf1 is offline
Proud F1 Owner
52flatheadf1 is starting off with a positive reputation.
Sorry to bring up an old thread, but I just bought a 52 ford f1. Previous owner put in an electric fuel pump and left the mechanic fuel pump mounted to the intake, but disconnected except for the vacuum line. Should I at least disconnect the vacuum line to it? If I do, and I do a PCV on this, can I plug the PCV into that vacuum port? Sorry for my ignorance, I am new to working on these vehicles and want to learn!!
Thanks!
Old 07-07-2015, 11:45 PM
ALBUQ F-1's Avatar
postin' fool
Welcome to the forum!
Is your fuel pump the kind with both a fuel pump and a vacuum pump? It sounds like it. If the vacuum pump still works, just leave it be. Are the fuel connections plugged, or does it also work?
No, the PCV cannot go to that vacuum connection.
fuel pump anthony f47 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-30-2016 07:00 AM
1951 V8 Oil Pan Flywheel Housing ssg1957 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 01-27-2015 09:48 PM
Uh-Oh! fixnair Flathead V8 & Flathead 6 3 08-20-2013 04:46 PM
Flathead Aluminum Intake Manifold 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-28-2011 06:11 PM
Who's best source for Fuel Pump for 1951 Ford F6 w/254 M-series 6-cyl engine? danhoward 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-01-2010 07:37 PM
Tags
193253, 1951, 1952, block, cover, enjines, f, f1, flathead, ford, fuel, pictures, plate, pumb, pump, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
