Wheel base question
on
Wheel base question
I found that one of my M-3 leaf packs are cracked. I'm now gonna use the rear leafs of the F-1. My wheelbase will be 0-1" off will this matter a whole lot? The best $50 I'm ever spent was for that parts truck. I'm using the rear end, leaf springs, front brakes and other little things.
on
Wheel base question
Nathan,
Since the M-3 rear springs are 2 1/4 inches wide, I think you will also have to change the spring hangers and shackles to use the F-1 springs as they are 2 inches wide. It might be easier to get a replacement leaf for the M-3 spring. I don't think less than a one inch change in the wheelbase will be noticeable, but if you have to replace the hangers, is redrilling the hanger mounting holes a possibility to get the original wheelbase back?
on
Wheel base question
Nathan,
Another thought...if you are changing the hangers anyway, I've heard that you can mount them higher up on the frame which will result in lowering the truck more...if you're interested. I may be doing something similar when I get around to re-doing my rear springs. There are 13 leaves, so I plan to remove at least half of them. If I run into any cracked leaves like you did, I may opt for F-1 springs also. I will also be looking into the possibility of using the rear springs from my 87 5th Avenue donor car, but I do not know yet if that will work.
on
Wheel base question
Nathan,
The rear is always higher than the front anyway in stock trucks. I don't think moving the hangers up would in itself lower the rear so much that it would be lower than the front. At the worst it might become more level front to rear. I think the use of F-1 wheels and springs will do more to lower the rear than moving up the hangers.
on
Wheel base question
Nathan
I don't know what's involved, but get the WB correct if you can. If you move the axle only one inch in either direction, the difference in clearance from one side of the wheel to the other becomes two inches and will be pretty noticeable.
Hope I didn't blow you away with that fancy math.
Wheel base question
Originally posted by 51dueller
I will try my best! Sir yes Sir. I didn't ask for try I meant do! Sir yes Sir! I will do my best.
