Anyone up for a challenge?? - Ford Truck Enthusiasts Forums
Old 09-20-2011, 09:45 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is online now
fifty-two_f1 is starting off with a positive reputation.
Heres what I have. I need a heater core whose dimensions of the core itself are 7 7/8 x 2 1/2 x 7 3/4. I do not care about the tanks. I will be soldering on different ones. Heres the kicker.... They cannot be aluminum (because I have not figured out how to solder to that) and they need to be cheap. I have been looking for a while and no luck. I have seen cores for like 80s pickups for instance in the 20 -30 dollar range which would be great. If you are bored HAVE AT IT!!!! THANKS!!
Old 09-21-2011, 08:17 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
If you still have your old one, you could try taking it to NAPA and see if they can match it up...
Old 09-21-2011, 10:06 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Believe it or not, I found a comprehensive list of heater cores on a site for high-performance computers. They apparently use them to cool off "hot" computers. It's a spreadsheet, two of them actually, one tells all the dimensions, the other cross-references from the FEDCO model number to a make and model of car that it's used on.
There are lots of them near the size you want, none exactly the same, and most are thinner (which may not be a problem). I'll send you the native XLS's off-line.
'71 F250 w/ AC heater core Norton72 1967 - 1972 F-100 & Larger F-Series Trucks 4 11-18-2014 10:28 AM
Magic Air Heater Cores BlueOvalRage 1948 - 1956 F1, F100 & Larger F-Series Trucks 65 01-05-2013 04:22 AM
Doing idm mod Farmboypowerstroke 1999 - 2003 7.3L Power Stroke Diesel 8 10-21-2010 08:33 PM
Rosin core vs silver solder b4hntn 1978 - 1996 Big Bronco 6 12-07-2009 12:27 PM
leaking rad, 77.5 f250 can i solder it? gingerbreadmaniac 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-27-2005 02:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
