2 or 4 wheel abs?
Is 2 wheel ABS on the front or back?
That's good if you didn't buy the truck pre-owned and the previous owner had replaced hubs once before. Hope that came out right. I had the same question. Is there a way to know if you have 2 wheel or 4 wheel ABS? I am the third owner of my truck and second owner had replaced huds once, left a few parts out. He went with the ones with ABS connectors because they were cheaper and in stock, the cut the connectors off. He said he "thought" that was the same way it was when he got it. I went with the hubs without the connectors because I did not notice the way he did the old ones until I got them off.
I have only 2WABS, rears only, I too have the hubs with the sensor installed wiring cut off, so that I can grease them yearly, the connectors for the front ABS are at the rear of the inner fender, and are not connected to anything on mine, I guess if someone installed ABS hubs and ran the wiring it could appear to have front ABS, then you would need to look at the ABS module under the battery on DS.
As I discovered today, there IS a difference between rotors for a early 99 with ABS on the front and without ABS on the front.
The early 99 with NO ABS on the front has a smaller diameter spindle. An early 99 WITH ABS has a larger spindle.
The rotors for one will not fit another.
This is disappointing to learn after you have jacked the truck, removed the brakes, and removed the rotor.
I can't speak for other year models though....
If you have ABS on the front, you will have two lines going to the caliper. One for brake fluid and one for the ABS. If you do not have ABS, you will have only the brake fluid line going to the caliper.
Can I assume this statement is referring to 2wd rotors/spindles? 4wd rotors should be the same, 99 and up right?
However, the Hubs remain unchanged other than the ABS Sensor. Which, can be used on ABS / Non-ABS Systems. There is only wiring, which signals the ABS Module and it (ABS Module) limits the pressure pulsation.
on
https://www.ford-trucks.com/forums/1...e-factory.html
JoeVR5
1983 - 2012 Ranger & B-Series
02-06-2010 05:28 PM
