2 or 4 wheel abs? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
2 or 4 wheel abs?
Old 09-20-2011, 06:42 PM
PEI PEI is offline
PEI is starting off with a positive reputation.
2 or 4 wheel abs?
Dont have my truck here right now to check, but does anyone know off hand if its 2 or 4 wheel ABS? need to pick up some rotors.
2001 F350 Super Duty Crew cab 2WD diesel
Thanks!
Old 09-20-2011, 06:44 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
It was optional, the only real way to tell is if it has the wiring going to the hubs, rotors should be the same regardless though.
Old 09-20-2011, 06:46 PM
PEI PEI is offline
Thanks
Guess I will wait and double check.. The place I was going to order them from wants to know before they ship them.
Thanks,
Jason
Old 09-20-2011, 06:51 PM
BigAlsPSD's Avatar
I know the rotors are different for 2WD vs 4WD but I didn't think there was a difference in whether or not you had RABS or 4WABS
Old 09-20-2011, 07:10 PM
PEI PEI is offline
Thats what I thought.. The connector is not on the rotor, but the caliper right?
Old 09-21-2011, 05:45 PM
Bobbys Big Red Rig's Avatar
Bobbys Big Red Rig Bobbys Big Red Rig is offline
Bobbys Big Red Rig is gaining momentum as a positive member of FTE.
Quote:
That's good if you didn't buy the truck pre-owned and the previous owner had replaced hubs once before. Hope that came out right. I had the same question. Is there a way to know if you have 2 wheel or 4 wheel ABS? I am the third owner of my truck and second owner had replaced huds once, left a few parts out. He went with the ones with ABS connectors because they were cheaper and in stock, the cut the connectors off. He said he "thought" that was the same way it was when he got it. I went with the hubs without the connectors because I did not notice the way he did the old ones until I got them off.
Is 2 wheel ABS on the front or back?
Old 09-21-2011, 05:50 PM
Quote:
Originally Posted by PEI View Post
Thanks
Thanks,
Jason
Sorry if I Hi Jacked, was just looking for a piggy back ride.
Old 09-21-2011, 06:41 PM
JOHN2001's Avatar
JOHN2001 JOHN2001 is online now
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
If its 4wd with 4WABS you should have one line running to the caliber, one line running to the ESOF (if you have it) and one line running to the top of the hub
Old 09-21-2011, 09:56 PM
BigAlsPSD's Avatar
I have only 2WABS, rears only, I too have the hubs with the sensor installed wiring cut off, so that I can grease them yearly, the connectors for the front ABS are at the rear of the inner fender, and are not connected to anything on mine, I guess if someone installed ABS hubs and ran the wiring it could appear to have front ABS, then you would need to look at the ABS module under the battery on DS.
Old 09-21-2011, 10:24 PM
bigtexan99 bigtexan99 is offline
bigtexan99 is gaining momentum as a positive member of FTE.bigtexan99 is gaining momentum as a positive member of FTE.
As I discovered today, there IS a difference between rotors for a early 99 with ABS on the front and without ABS on the front.
The early 99 with NO ABS on the front has a smaller diameter spindle. An early 99 WITH ABS has a larger spindle.
The rotors for one will not fit another.
This is disappointing to learn after you have jacked the truck, removed the brakes, and removed the rotor.
I can't speak for other year models though....
If you have ABS on the front, you will have two lines going to the caliper. One for brake fluid and one for the ABS. If you do not have ABS, you will have only the brake fluid line going to the caliper.
Old 04-11-2015, 11:04 PM
dfoxengr dfoxengr is offline
dfoxengr is starting off with a positive reputation.
Can I assume this statement is referring to 2wd rotors/spindles? 4wd rotors should be the same, 99 and up right?
Old 04-11-2015, 11:24 PM
whitetmw whitetmw is offline
whitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to allwhitetmw is a name known to all
Quote:
Actually, it's build date. I "believe" it is 6/99 forward but may be 5/99.
However, the Hubs remain unchanged other than the ABS Sensor. Which, can be used on ABS / Non-ABS Systems. There is only wiring, which signals the ABS Module and it (ABS Module) limits the pressure pulsation.
Old 04-12-2015, 08:27 AM
jhl3's Avatar
jhl3 jhl3 is online now
jhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to behold
Check out this link to a post and see if this helps:
http://www.ford-trucks.com/forums/13...e-factory.html
1940 Ford Pickup 1/2 Ton Specs Alanok 1947 and Older Ford Trucks 21 06-30-2016 06:51 AM
Hate Selling The Ex (photos on my profile) Elmo154 Vehicles for Sale 2 04-19-2016 03:58 PM
Rookie in San Diego Ken Ishmael 1997 - 2003 F150 1 07-11-2014 12:39 AM
THIS is what ill be driving 351Cleveland C4 The Next Generation 23 09-23-2013 07:00 PM
2002 F250 rear rotors. Pull the axel shaft? pcctim 1999 - 2003 7.3L Power Stroke Diesel 8 04-14-2009 12:45 PM
Tags
2000, 2003, 2004, 2or, 2wheel, 4wd, 4wheel, abs, difference, f150, f250, ford, ford73350fourabsbypass, rotors, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
