manual steering draglink 1975
im looking to make a draglink to go from my manual steering box to my install stock dana 60 front axle. i was wondering if anyone knows what the taper is and such for the stock 75 arm and the stock 78 d60 front arm
i took my stock ps ram and draglink valve off and sold it and want to just be able to move it around the farm to get it outa the way once in a while or pull trees down and dont need or am not ready for the intragal PS upgrade yet.
thinking if i knew the taper and such i could just get a couple tie rode ends and a threaded sleave thats common at the parts stores.
Thanks.
Skip
Thanks.
Skip
ya i got one of them reamers, its the big gm taper one. works great. maybe i should ream it out to gm later after i convert it to intergal power steering.
I just checked my reamer and it has a taper of 1.5 inches per foot.
FWIW: I don't think ya need to ream it to GM specs. I swapped to integral PS on my rig and the drum equipped D44 steering arms just needed to be reamed for the 79 Bronco tie rods. The tie rod shanks/studs are much thicker on the Bronco and I didn't have enough stick-out to seat the nut and cotter pin.
i think the reamer i got has 1.5 per foot, xkut one, its really nice, cost a pretty penny too.
so what is the taper on the fords dana 60?
Golden Helmet
07-22-2014 10:08 PM
bigred460ci
02-26-2008 05:45 PM
Code3
06-20-2006 02:36 PM
woodyropes
11-16-2001 08:23 AM
