Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
  #1 (permalink)
Old 09-20-2011, 12:34 PM
Engalwood Engalwood is offline
Garage is empty, add now
Engalwood is starting off with a positive reputation.
2001 F650 Long Steak Bed HELP..........
We have had this problemo for a long time now and cant come up with a fix. I dont know if this is the right place to post, as I didnt see a fourm for f650s? The motor is a Cummings ISB225(I believe). It seems that some times it runs just fine and more then none it runs like a rouf idel. Its like the motor fluxuates alot up and down. It seems that maybe starving for fuel? I have no idea that. We have spent a lot of $$$$ taking to places and no one can come up with a reason whys its running like crap. When you go to shift gears it still does it. But some times when u are on the highway and get up to speed it drives just fine, like nothings wrong. We had the ecu replaced, took to Ford and thats what they said was the problem so we did that, work for a few days seemed like, then back to a rufffffffff running motor. Had the Alt changed bc we wer told that could cause the problem (which had a bad dioed). Didnt work. Im just at a end to were I dont know what to do are look, are think ..... Does any one have any suggestions to what it might be? Thanks again guys!!!!!
  #2 (permalink)
Old 09-20-2011, 12:58 PM
Pili's Avatar
Pili Pili is online now
Pili is starting off with a positive reputation.
Quote:
Here is the link for the 450+ forum Large Truck - Ford Truck Enthusiasts Forums
__________________
Oxford White 1999 Ford Lightning #3326
  #3 (permalink)
Old 09-20-2011, 10:32 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the Large Truck forum.
__________________
John
2011 F-350 4x4 Lariat Ultimate, Oxford White / Pale Adobe 6.7L PSD 3.55 ELD / Gone but not forgotten.
2013 Ford Taurus SHO, Tuxedo Black / Black Leather
Moderators, Guidelines, and How They are Enforced / FTE Forum Guidelines
Currently truckless
  #4 (permalink)
Old 09-21-2011, 03:20 AM
Louisville Joe Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.
Anyone hook a scanner up to this truck and check for codes? Could be a dozen different things. I can tell you something it MIGHT be. Did you check the transfer pump? Could be the injector pump isn't getting enough fuel, and on the ISB series Cummins, fuel from the transfer pump cools the ECM. Low fuel pressure from the transfer pump will set a specific DTC. And, Cummins has an updated transfer pump kit for many ISB's. You really need to scan this thing and find out what's going on with it. Don't just throw parts at it.
  #5 (permalink)
Old 09-21-2011, 06:12 PM
80broncoman 80broncoman is offline
80broncoman is gaining momentum as a positive member of FTE.
We had a truck at my work that all of a sudden starting running bad. turned out someone had stuck a Candy bar wrapper in the fuel tank and it of course went to the pickup and plugs it up about 95%.
it would idle all the live long day, but when you stepped on the pedal it was gutless.
I'd look inside that tank.
__________________
GM=Got Mechanic?
77 F-150 4X4 400/4sp
80 Bronc 300/4sp
89 F-450 7.3/5sp rollback
94 F-700 5.9/6spd (camper/hauler project)
  #6 (permalink)
Old 09-25-2011, 05:01 PM
CF LN7000 CF LN7000 is offline
1990 Ford Heavy Duty
CF LN7000 is starting off with a positive reputation.
ISB cummins in the F650 chassis are KNOWN for Lift pump (transfer pump) issues. Like Lousiville Joe said, fuel is drawn from the tank, through a screen filter primary inside the frame rail, through the transfer pump and then pushed thru the ECM cooler plate before it goes into the HP pump. When you key on, there should be an obvious noise of a electric motor working near the Left front of the engine for 10+ seconds (not to be confused with the brake booster on the firewall). If you hear nothing, or a noise that doesnt sound strong, or sounds erratic, replace the pump AND the Ford screen filter on the frame rail. That came back to bite a fellow co-worker at our shop before. The screen was plugged and no one knew the filter was there in-line and it took out 3 lift pumps before we realized what the deal was and that is was a filter element hidden in the frame rail. Everything your describing points towards the lift pump.
  #7 (permalink)
Old 09-26-2011, 06:20 AM
Lou Joe, We werent just trowning parts at it. I just was explaing that we have taking to many diferent shops EVEN FORD, and this is the stuff they have done to it thinking it was the problemo.. Scanig it means taking it to ford? Are runing a simple scanner?
  #8 (permalink)
Old 09-26-2011, 06:22 AM
Is this screen you are talking about inside the tank? Are inside the fuel line itself? Id like to take a look at this stuff today...
  #9 (permalink)
Old 09-26-2011, 06:41 AM
This chit sounds like its going to hit the wallet hard!!!!! It there a way to test this before we just replace it???
  #10 (permalink)
Old 09-26-2011, 06:49 AM
The filter is located on the inside of the frame rail. Drivers side about midway point of the engine. Its inline with the suction line. Looks like a 3 inch round gas filter, but its a screen filter. Black with quick disconnect fittings in it
  #11 (permalink)
Old 09-26-2011, 07:05 AM
not seeing it? I unnno wtf im lookn for lol.... I dont seee anything that looks like this :/
  #12 (permalink)
Old 09-26-2011, 07:10 AM
I see somethings thats about 3 inches its alum.. Fuel line does run to it, dont see disconnect fiting but does look like it might unscrew. It also does have a part of the harness runnig to it? Is this it?
  #13 (permalink)
Old 09-26-2011, 07:39 AM
Ok, after closer inspection. Doesnt unscrew. Has a hose on side unscrews, and a hose at bottom with a bolt that unscrew. Would this be it? This is all I see... And is this replaceable?
  #14 (permalink)
Old 09-26-2011, 07:55 AM
Ok, we have had the Fuel Supply pump, and fuel Injector pump replaced back in 07. We had that done and it did nothing to fix the problem. Note Young and Sons Auto is not a place to go if you are in Indianapolis!!!! Just keep saying this was bad and replaced it and still have the smae problemo :-0
  #15 (permalink)
Old 09-26-2011, 08:39 AM
I have looked every where online to see if I am looking at the right thing. google n all lol, cant find a picture are nothing about this inline fuel screen. Starting to bother me alot, please help guys, Even looked in the tech folder here. :-O
Tags
1963, bed, f650, filter, ford, frame, fuel, number, part, rail, specs, steak, steakbed, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
