1956 Truck AOD bellhousing mount - Ford Truck Enthusiasts Forums
Old 09-20-2011, 06:57 AM
ke6jcf's Avatar
ke6jcf ke6jcf is offline
ke6jcf is starting off with a positive reputation.
I have a 56 truck with a 292 Y in it and an AOD. I have purchased a Bendsten's adapter and all is OK, but the bell housing mount. I have long headers which prohibits side mounts on the block. I think there are bolt on bellhousing mounts for chevy's that they use in racing. They bolt to the bellhousing and then to a mount sort of like the tri fives bellhousing mount. Does anyone know if there is such a mount for a Y Block out there? I'm going to use the stock front mount and a tailshaft mount, so torque will be a deffinate issue! |
Thanks in advance
Doug
Groundwire mounting options pat420swed Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 10-26-2015 09:48 PM
58 F100 T-19 and 351W Studebakerhawk 1957 - 1960 F100 & Larger F-Series Trucks 10 08-28-2015 09:06 AM
292 3spd Bellhousing Rockydm 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 02-04-2015 02:18 PM
T18 Bellhousing Numbers 79F150EFI Clutch, Transmission, Differential, Axle & Transfer Case 14 03-26-2014 11:36 PM
bellhousings 55 f350 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 03-16-2014 12:30 PM
Tags
1956, 44, 56, aod, automatic, bell, bellhousing, diesel, f100, ford, housing, mount, mounts, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
