1951 F1 Front End Lowering - Ford Truck Enthusiasts Forums
Old 09-19-2011, 10:00 PM
1951flatheaddave 1951flatheaddave is offline
1951flatheaddave is starting off with a positive reputation.
Hello everyone, I am getting ready to do the spring over axle drop in the rear and was wondering what was the best way to lower the front to match the rear drop? I am going to use the TCI Leaf Spring kit for the rear since it comes with all new leaf springs and seems like a complete kit for the rear. I saw LMC truck sells front lowering springs but wasnt sure if that was the best way to go. What have you done?
Thanks, Dave
Old 09-19-2011, 10:22 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Hi Welcome to FTE! I have a Jag IFS under the front of mine, but not on the road yet, not even close! I know there are lowering leafs, there are also lower axles, sort of a drop spindle built into the axle, and you use something different with the tie rods. Sorry for not knowing, but someone will chime in soon to fill in the blanks for sure!
Old 09-20-2011, 01:49 AM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
IFS or stock drop front axle I got the same rear tci spring setup with a tci muxtang 11 IFS. DROPS it 4'' front and back. Drives great !!!!
Old 09-20-2011, 01:56 AM
pic. of my truck
It will set like mine in the pic. Note ifs with stock spindels not droped spindels.
Old 09-20-2011, 06:23 AM
Truck looks great!!! Where can I get a drop straight axle?
Old 09-20-2011, 08:27 AM
Old 09-20-2011, 09:19 AM
flaharleyguy flaharleyguy is offline
flaharleyguy is starting off with a positive reputation.
Quote:
Originally Posted by Jeff and Nicolle View Post
Very nice stance! BTW the sun visor you have any info on it> I would like to get and install on my project as well. Thanks
Old 09-21-2011, 01:09 PM
Fordman49F1's Avatar
Fordman49F1 Fordman49F1 is offline
Fordman49F1 is starting off with a positive reputation.
Contact Sid here about drop axles...from what I have been told through my searches for lowering solutions, he is the best in the business and he uses your stock Ford casting. Good stuff.
As mentioned, you are looking at IFS or drop axle to lower it that much. You can get a few inches by using saggy old springs and remove a few. There is a thread on the HAMB right here that talks about lowering...it is a must read for any F-1 owner that wants to lower their truck in my humble opinion.
Good luck!
Old 09-21-2011, 01:46 PM
I am about to order the Posie front Super Slider springs. Good idea or no?
Old 09-21-2011, 02:23 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Quote:
I would do a little more research on the Posie springs - I've heard a number of yes and no's on them
Old 09-21-2011, 02:25 PM
I'm tellin ya...read that article on the HAMB...it talks about a ton of options he made and why exactly he made them.
Old 09-21-2011, 02:27 PM
4tl8ford's Avatar
Don't you have to "C" notch the frame to do a spring over drop in the rear?
Also there can be steering linkage issues with the dropped axle - You need to satisfy yourself that you can deal with these.
Old 09-21-2011, 02:42 PM
You actually don't even need to do a spring over to drop the rear...
And yes you do need to get tie rod end drops if you lower the front end over an inch I believe.
Old 09-21-2011, 04:34 PM
ZOOT's Avatar
ZOOT ZOOT is offline
ZOOT has a good reputation on FTE.ZOOT has a good reputation on FTE.
Drop spindles or dropped axle will require changing the steering geometry. As mentioned before tie rods, and the drag link will no longer be parallel to the frame. Not good for handling and won't improve ride quality. If you have the $ an IFS set up is much better. I dropped the rear by the leaf springs below the axle and an IFS in front.
My rear end needs a boost...kinda xmontex4 1999 to 2016 Super Duty 22 10-04-2013 11:59 AM
lowering the 53 jozan 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-06-2012 09:45 PM
Lowering my 53 f100 and need some help chappys4life 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 04-14-2012 05:16 PM
1951 F1 Front Leaf Spring Question 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 11-08-2011 07:34 AM
1951 F1 Wheel Size Question 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 09-30-2011 01:52 PM
Tags
1951, 1966, 49, 51, blocks, end, f1, ford, front, hiw, lower, lowered, lowering, motor, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
