Wrench light
Wrench light
Just got my truck out of shop at dealership, drove about ten miles and now my wrench light is on. They replaced egr cooler and front cover of the motor, flushed motor , the oil side and coolant side.
They said the loss of water caused the pump to cavitate and eat a hole in the front cover allowing water to mix with oil. Does that sound right?
Now the wrench light is on.
How long were you driving your truck after it started losing that much coolant?
This is a very BAD thing for these engines. A hole in the front cover will allow your coolant to drain into the oil sump, which can cause rapidly increased wear for the engine internals.
We've seen lots of rocker arm lubrication failures after 100,000 miles, and some attribute it to fuel or coolant in the oil. This needs to get taken care of ASAP! Also, I suggest asking your dealer how much antifreeze made it into your oil.
Ken_powerstroke00
6.4L Power Stroke Diesel
15
10-15-2018 09:25 PM
93FordCTD
10-19-2013 07:17 PM
Jim McCarty
02-20-2009 10:32 AM
