Wrench light - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Wrench light
Old 09-19-2011, 08:33 PM
bigcountryfs bigcountryfs is offline
bigcountryfs is starting off with a positive reputation.
Wrench light
Just got my truck out of shop at dealership, drove about ten miles and now my wrench light is on. They replaced egr cooler and front cover of the motor, flushed motor , the oil side and coolant side.
They said the loss of water caused the pump to cavitate and eat a hole in the front cover allowing water to mix with oil. Does that sound right?
Now the wrench light is on.
Old 09-20-2011, 05:04 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Yes that is how it happens. Have to stay on top of your fluid levels.
Wrench light is means there is another problem somewhere.
Maybe thermostats now.
Old 09-20-2011, 06:21 AM
i had noticed my truck blowing some white smoke out and starting to run rough when i accelerated, that is when i checked it out. started adding 4 gallons of water a day (3-days) untill it went into the shop.
Old 09-20-2011, 07:07 AM
senix's Avatar
Cavitation could have been caused by a few things. Primarily from low coolant levels allowing air to get inside the motor.
Old 09-20-2011, 09:12 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
How long were you driving your truck after it started losing that much coolant?
This is a very BAD thing for these engines. A hole in the front cover will allow your coolant to drain into the oil sump, which can cause rapidly increased wear for the engine internals.
We've seen lots of rocker arm lubrication failures after 100,000 miles, and some attribute it to fuel or coolant in the oil. This needs to get taken care of ASAP! Also, I suggest asking your dealer how much antifreeze made it into your oil.
Old 09-23-2011, 09:20 PM
only drove it about 250 miles having to add the water. went back to dealership for wrench light. they said it had a restriction at the egr cooler sensor, now have to replace the egr cooler.
water separator and wrench light on? SUPERDUTY_08 6.4L Power Stroke Diesel 11 03-08-2015 09:15 PM
wrench light 05 f 250 bcollison98 6.0L Power Stroke Diesel 5 07-21-2013 06:53 AM
Wrench Light on in Dash Help! jfralph 6.0L Power Stroke Diesel 11 08-13-2012 04:02 PM
29 PSI - Wrench light - Overboost? kidoo 6.0L Power Stroke Diesel 12 09-19-2011 07:26 PM
Do you have the tools to replace your filters? alfie623 6.0L Power Stroke Diesel 20 03-02-2005 06:43 PM
Tags
2008, 64, diesel, display, edge, f250, ford, light, power, slipping, steering, transmission, wrench, wrenchlightonfordf350
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
