I no there is many 4x4 problems,Mine is diferent
I have a 97 f150 4x4 with a automatic transmission and a manual floor shift for 4x4, my 4x4 only works when it want to,sometimes when I shift in 4h the light comes on and goes right in and 4x4 is engaged,and other times when I shift in 4x4 no light and will not engage,can anybody point me in the right direction,when I go to work on the dam thing it seems fine, but when I need it, it will not go in 4x4 for nothing...
You have the manuel shift control to begin the the process.
It signals a GEM module that in turn runs the tranfer case motor to the position you select 4H or 4L. Note that in 4L it changes the PCM shift programming as well.
Then the GEM operates a firewall relay to route vacuum to the front actuator.
With intermittant operation it can be anywhere along these paths.
You have to try and see where it stops the process either electrically or hardware wise.
A hint is the 4H or L lamp is lighted when the selected function is complete. If it comes on, goes off or flashes, any other time, it's a malfunction.
Good luck.
Good luck.
Look at the 4th line in my reply.
What does it say? If the actuator does not work no front drive!
The actuator is mounted on the front housing and is operated by vacuum.
Is the actuator good? Is the vacuum lines to the solenoids and actuator good? etc.
You have to translate the info offered and work on it.
Good luck.
Good luck.
come on dude give me a break ,I read all your answer including line 4,on the front differential,there is a actuator with a vacuum line and a wire going to it and the vacuum line is closed off with a bolt in it,but why does it work sometimes, if its not getting any vacuum at all,and when the light inside comes on the trucks 4x4 works great, with no problems..
as bluegrass said, there are two solenoids on the firewall. VAcuum line to to them. two vacuum hoses out of the solenoids go to the front axle. vacuum on #1 and it engages. Vacuum on #2 and it disengages. Just a small vacuum cylinder that goes in and out. If either hose is plugged, your screwed. Pull both hoses off and check vacuum as you move the shift lever.
