Old 11-12-2014, 12:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
How do you reset the oil life monitor?
Old 09-19-2011, 05:55 PM
Tacswa3's Avatar
Tacswa3
Tacswa3 is offline
Couldn't find anything searching the board. Just changed my oil and I can't figure out how to reset the oil life monitor. I changed the oil before the truck advised to. My manual shows a button with setup and reset that DOES NOT match any buttons I have on the steering wheel. I have a Lariat w/ the 4.2 LCD Screen. I appreciate any help.
Old 09-19-2011, 07:05 PM
KC8QVO's Avatar
KC8QVO
KC8QVO is offline
It should be under "maintenance" and "oil life reset". I poked around my screen and found it when I changed my oil. It works the same as the MPG reset - you have to hold the button down to get it to take.
Old 09-19-2011, 08:17 PM
Tacswa3's Avatar
Tacswa3
Tacswa3 is offline
Actually I figured it out. You have to go under "settings" then choose "reset oil life" or something to that effect. Then hold down the 'ok' button to reset.
Old 09-20-2011, 09:27 AM
don.joyce59's Avatar
don.joyce59
don.joyce59 is offline
Glad you found it. I had trouble the first time also. The manual doesn't fit trucks with the 4.2 screen. I had to have the dealer show me the first time.
Old 09-20-2011, 01:10 PM
KC8QVO's Avatar
KC8QVO
KC8QVO is offline
I am sitting in the truck now - go to "settings", then scroll down to "vehicle", then "oil life reset". Push and hold "OK" like you do for mpg and trip resets.
Old 02-21-2016, 04:29 PM
dopeyred's Avatar
dopeyred
dopeyred is offline
I found this site to be helpful for oil life resets on any Ford: https://carhowto.com/reset-ford-f150...-change-light/ They have videos and step by step for every car I run into. Hope this helps someone.
egregg57
6.7L Power Stroke Diesel
08-15-2016 02:36 PM
Pit Crew
1999 to 2016 Super Duty
02-12-2015 11:32 AM
Vicky Terry Smith
17
01-22-2015 03:10 PM
burrhead
6.2L V8
07-09-2011 12:12 AM
LTCPipkin
03-23-2009 06:29 PM
Quick Reply: How do you reset the oil life monitor?
