Help me find a 5 lug Dana 70!
Old 09-19-2011, 02:42 PM
1949 F6's Avatar
1949 F6
1949 F6 is offline
I need a 5 lug dana 70 axle but am having one heck of a time finding one. I would prefer a 4.10 ratio but I'm open to anything at this point. I am located in Denver so one within a few hundred miles would be nice. Anyone have any leads?
Old 09-19-2011, 04:03 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
Did you maybe ask the guy in Denver that you got your spare 19.5" wheel from. If he had three wheels for sale, might he also have disposed of the motorhome? It could be in a yard nearby. A month or so ago I'd have known of a Dodge motorhome with Dana 70 in the Portland area that I got the wheels and tires off of, but must assume it's gone to the crusher by now. I'll watch Craig's List. Stu
Old 09-19-2011, 04:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Check with Martin's Supply, near Windsor, CO 970-686-2460.
Old 09-19-2011, 06:01 PM
truckdog62563
Old 09-19-2011, 07:46 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,051 Likes on 802 Posts
I'll also add some early '70s IH trucks had the five bolt pattern wheels. I parked next to a guy at a power show a few years back who used an IH rear axle under his F-5, he also had a '70s IH truck parked next to his F-5. He told me the inards of the same as a Ford of the same vintage. He said he bought a set of higher gears from some west coast Ford truck dealer and installed them in his IH rear end.
Another avenue to explore.
Old 09-19-2011, 08:39 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Dana 70: 1963/85 F350 (except 1979/85 4WD) / 1975/2011 E350.
1963/66 F350: 6 lug wheels on a 7.25" bolt circle / All others: 8 lug wheels on a 6.50" bolt circle.
Old 09-19-2011, 09:08 PM
truckdog62563
Bill - If I may I'll take you back a few years and reference a private message I sent you asking about wheel #D3TZ 1015-C. At the time I had just bought two NOS wheels that still had the Ford part number tags attached. These wheels are the Budd #89340s that fit the axle member "1949 F6" is trying to track down. Most often we associate this application with Dodge based motor homes, but in truth Ford used it too. You told me the above wheel was used on 1973 to 1976 model M-450/500 motor homes that were built in Louisville. You said it was a unique motor home chassis, not an E-350/450 or F-350/450 chassis. With this information, is it possible to determine whether the axle used in that Ford chassis was also a Dana 70 as was used in the Dodge based model? And if so, can you tell what the final drive ratio was? Stu
Old 09-19-2011, 09:26 PM
NumberDummy
M450/500's are listed in the 1973/79 Ford Light Truck Parts Catalog:
1973/74 M450/500: Rockwell model C100 (11,000 lb capacity) or D100 with/without Limited Slip (13,000 lb. capacity) / 1973/76 M450/500: Rockwell model D104 (13,000 lb. capacity).
Old 09-19-2011, 09:49 PM
truckdog62563
Thanks Bill. That Rockwell reference might then connect the dots with Bob's above reference to a similar axle used by IHC. Stu
Old 09-19-2011, 11:52 PM
brain75's Avatar
brain75
brain75 is offline
I assume that upullandpay has already been hit, but I'll toss it out. they will "do their best" to find the interchange, but my experience they aren't the bright crayons. You tell em you want an 61.25" wide ford 9" and they won't come up with the list that we all know (57-72 f100 2wd)... After you get some more makes models (dodge power wagon?) then you can dig through their stuff or not ($2 entry fee). East of Greeley out by the airport (where I found my F1), is a junk yard used to be called Anderson's, but I think it is a uwrenchit or some such now - they have a slower rotation, they don't remove the older models and crush them so fast as upullandpay - so a little better chance at older stuff.
Old 09-20-2011, 12:15 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by brain75
... East of Greeley out by the airport (where I found my F1), is a junk yard used to be called Anderson's, but I think it is a uwrenchit or some such now - they have a slower rotation, they don't remove the older models and crush them so fast as upullandpay - so a little better chance at older stuff.
If you haven't been to Martin's, you owe it to yourself to visit! (It may actually be the one you are talking about?) It is acres and acres of old 50's trucks, cars, buses, farm equipment, you name it. It's right on US 34. Caveat: I haven't been there in a few years. When I was there they had at least 20 BonusBuilt cabs, not all cherry for sure, but it was like a candy store.
Old 09-20-2011, 05:45 AM
truckdog62563
Circling back to Bob's and Bill's references to the Rockwell axle and the IHC connection, here's a pic of one such model you'll want to watch for. This one was in a yard in SLC but is probably gone already. Josh Madsen got the 22.5" wheels off it probably 6 months or more ago before it was sent to China. But the picture is useful in helping you direct your search. Stu
Old 09-20-2011, 08:11 AM
jmadsen's Avatar
jmadsen
jmadsen is offline
Stu,
Are you saying that this yellow IHC may have the Axle in question under it? I haven't driven past this yard for a while but it was sitting there on blocks last time I did go by, a few months or so ago? I will call them in a while and see if it's still there. Did you see it when you flew through ogden last month???
Also a yard here in the valley that has a few older dodge Rv's that the 19.5s came off of, also has a ford stepvan/delivery with 19.5" 5 lug wheels on it, so I'm sure one could be found with the ratio you want?
I'll call there today as well and then pass his info along if you want to call to talk to the guy direct.
He runs a pallet business in the middle of the yard, and doesn't really want to sell any of the older stuff or parts (Ive tried, as I'm sure lots of other people have too) the good stuff will sit for a few more decades probably before he lets it go???? it's not really a junk yard or a U pull IT place, more just a guys large collection that was kind enought to sell me some wheels off a crusty old RV that the roof was collapsed.
Amazing what a couple of boxes of Girl Scout Cookies will do for ya when you need something!
Also another place to check is Fico truck parts in Ogden 801-782-7502
but I bet you can find something closer to home?
buy an old Rv for 400-500 and part it out get you axle for free!
Old 09-20-2011, 08:38 AM
truckdog62563
Originally Posted by jmadsen
Stu,
Sure, it's probably the Rockwell that Bill and Bob referenced. But I thought I recalled you saying that you got to the wheels right before it was scrapped. I would have stopped by there on the way through if it wasn't 4:30 a.m. local time. But since it's a military surplus yard, there could be others I guess. Stu
Old 09-20-2011, 08:55 AM
jmadsen's Avatar
jmadsen
jmadsen is offline
Well thats what they told me,
"come get the wheels if you want them because it's going to scrap!"
and when I finally got there to get the wheels I didn't expect to see the truck, but all they had pulled off where the wheels for me and the radiator for scrap so it didn't seem like they were in a huge hurry, (at least at the time?)
I doubt there were others, It's your friendly neighborhood Ace Hardware Store, heck they dont even open till 9:00 am
Quick Reply: Help me find a 5 lug Dana 70!
