Help me find a 5 lug Dana 70! - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-21-2011, 02:13 PM
1949 F6's Avatar
1949 F6 1949 F6 is offline
1949 F6 is starting off with a positive reputation.
Maybe not, can i get some more pics? How bad is the rust on the parts i need? Thanks!
Edit:I just saw your truck's ebay listing. The rust would be ok if it was a little closer, i would take it to the swap meet and if no one bites maybe we can work something out.
  #32
Old 09-29-2011, 07:15 PM
1949 F6's Avatar
Axle found!
Hats off to Josh! He found me what I believe is a dana 70 with a 4.56 ratio, which is perfect for the tires I'm running. I will be retrieving it at the end of november. I checked out Marin's scrap and they had over 30 bonus built cabs easy. One had an odd turbo looking thing haning off the right side of the exterior of the cab and was connected to the heater. Im guessing its the method of producing air movement but I havent ever seen one like it before. I didnt have enough time to check out Anderson's but I may later. Ill let you guys know how the swap goes when the time comes!
  #33
Old 09-29-2011, 07:27 PM
jmadsen's Avatar
jmadsen jmadsen is online now
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
That tube on side of the cab is the fresh air vent for the magic air heaters, you should get it for your truck. 30 bonus built cabs! Sounds like heaven to me....
1956 F350 to accept later 8 lug wheels on the front end,is it possible? old uhaul 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 07-20-2014 10:16 PM
1966 f350 dana 60 tnfarmer67 1961 - 1966 F-100 & Larger F-Series Trucks 5 03-17-2011 09:54 PM
Coil sprung dana 44 into 86 F250??? 86sixbanger Offroad & 4x4 20 03-04-2011 12:42 AM
Dana 44 5 lug to 8 lug??? 351slug Offroad & 4x4 48 01-29-2011 08:38 AM
5 lug dana 44 to 8 lug dana 44 mattjensen Brakes, Steering, Suspension, Tires, & Wheels 5 04-24-2009 05:28 PM
Tags
130, 1949, 195, 70, axle, dana, f600, fender, ford, lug, lugs, rearend, rockwell, sale, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
