Radio Antenna - Ford Truck Enthusiasts Forums
Radio Antenna
Old 09-19-2011, 01:44 PM
hwyhogg's Avatar
hwyhogg hwyhogg is offline
hwyhogg is starting off with a positive reputation.
Radio Antenna
Hi again,
I have a '56 panel truck with the antenna hole on the passenger side of cowl. It is about a 45 degree angle or so. Midfifty sells one, but it is over $60. While I've bought lots of good stuff from them, it seems expensive for an antenna. I see cheaper ones on ebay that "adust to 35 degrees..". Where did you guys with the mounting position like mine buy yours? My mounting hole is approximately 1" x 1.25", (kinda oval)...thanks for your continued help with this project,
James
Old 09-19-2011, 02:26 PM
Moe Craig's Avatar
Moe Craig Moe Craig is offline
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
in the 80's I replaced mine that was mounted there, I got one from Napa Auto Parts...
Old 09-20-2011, 12:15 PM
Steves55's Avatar
Steves55 Steves55 is offline
Steves55 is starting off with a positive reputation.
James, I had the same situation on my 55. Rather than sinking $60, I bought a universal (retractable mast) from Advance Auto Parts for $25. Fit perfectly. May be worth a try. Good luck. Steve
Old 09-20-2011, 05:52 PM
hwyhogg's Avatar
thanks. . I guess the angle is adjustable on the universal on you got from Advance? I will try one; they'll take it back anyway, so worth a try I would probably go electric if I'm gonna spend $60 to fill a hole BTW, for anyone else looking, I did call a company call Metra today. They recommended their part no. 44-UT03R I found it at Best Buy for 14.99...., but they will have to order it. Will see what the local part store has first
Old 09-20-2011, 10:10 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Hog,I'm not sure how married you are to having a stock appearance,but this is what I did.I got one of the short rubber antennas,and gave away the NOS one I had to another member.
The stock one is extremely long,and prone to being easily snapped off.That short black rubber one works fine,is discrete,and is forgiving while going through a carwash.If you want originality and "the look', it probably won't suit you.I'm sure it cost me less than 25.00.Keep in mind,my truck is a 59,but it is a universal fit.
Steve
Old 09-21-2011, 08:12 PM
hwyhogg's Avatar
BIG, do you have any pics of the rubber antenna? I tried one today from an auto parts store. It adjusted to "35 degrees", but it still was not vertical enough for me. I do like the shorter rubber look better than the stock look, but I want something more vertical...
thanks
Old 09-22-2011, 07:18 PM
hwyhogg's Avatar
Just an update and FYI for anyone in my situtation. I tried a few different antennas and for me the universal ones that "adjust up to 35 degrees" did not work...they were still cocked out too much. BUT, I did find one of the shorter black rubber ones, (which is better for the look I want) that works well I bought it at Best Buy, (you have to ask to look at their stock in the installation area of store). It is made by Metra . It is the AntennaWorks series and the product number is 44-US07R. On the tag it says Top/Side mount for 1"/25mm hole. My hole is about 1" x 1.25" and it covers and tightens nicely. This antenna has a ball swivel (above the base at bottom of antenna) that allows you to adjust the antenna to suit your taste. Would post pic, but that seemed like a complex ordeal on this site. It must be easier if you are a paying member? Any way, hope this opens up another option for those needing an antenna on the slant part of the cowl
thanks again,
James
CB antenna ManfredVonRichtofen 1978 - 1996 Big Bronco 15 01-09-2017 11:30 AM
Haulers/Road Warriors - Where do you mount your antennas? rowingdude 1999 to 2016 Super Duty 9 01-02-2015 11:47 PM
Need antenna CountryBumkin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-11-2014 01:26 PM
Tip for through-the-roof NMO mount antennas robert_l_ross Excursion - King of SUVs 4 11-22-2013 12:19 AM
Mounting CB antenna on truck box illini5190 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 12-03-2010 12:43 AM
Tags
1956, 1959, antena, antenna, antennae, antennas, audio, f1, f100, ford, good, hiding, radio, retractable, truck, trucks, vintage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
