"P0528, Fan Speed Sensor: No Signal" Found the problem need part. - Ford Truck Enthusiasts Forums
Old 09-19-2011, 02:17 PM
egregg57's Avatar
egregg57 egregg57 is offline
egregg57 has a good reputation on FTE.egregg57 has a good reputation on FTE.egregg57 has a good reputation on FTE.
It seems that my electric fan clutch on my 2005 F-350 (82,716 miles) has failed. The wiring back to the PCM is good, and I can't positively check the wiring to the fan clutch itself, I have no schematic for it. But in doing some research it seems that almost all of the time, when this code is shown, with no visible wire damage, the electric clutch has failed.
Does anyone have a good resource for this part? I have seen ones advertised for as much as 447.00 and as little as 156.00. I want a quality part with out getting taken to the cleaners!!
Thank you!
Old 09-19-2011, 03:27 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Try Tousley Ford parts.
Tousley Ford Parts Depot
Cooling system - Cooling fan - Fan clutch
Fan clutch, f350, 6.0l diesel
03-07 $470.38
Your price-----------$284.58
Old 09-19-2011, 03:29 PM
Thought it would copy page for fan clutches, but it didn't.
Old 09-19-2011, 08:28 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
The part number for the standard fan clutch is: 4C3Z-8A616-AA
The heavy duty "snow plow" clutch is: 4C3Z-8A616-SA (around $300 at Tousley)
Old 09-20-2011, 07:24 AM
egregg57's Avatar
Thank you both for the input! I have a camping trip this weekend, I will get this replaced afterward. In my driveway, more than likely!
Eric
Old 09-20-2011, 07:52 AM
i eat hybrids's Avatar
i eat hybrids i eat hybrids is offline
i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.
Did ur P0528 code stay all the time or was the code poping up intermitentally?
Old 09-20-2011, 08:03 AM
egregg57's Avatar
Quote:
It was intermittant, initially. I could clear it, but the next time, or the time after that when I drove, it would come back in. It has since become locked in steady. At least its a straight forward repair and easy enough to do. I plan on getting this done probably next payday.
Eric
Old 09-20-2011, 09:58 PM
Mines intermittant to. Where ur temps kinda high? Im thinkin i have the same issue. Is their a write up on this fix?
Old 09-20-2011, 10:50 PM
bismic's Avatar
Old 09-21-2011, 07:14 AM
egregg57's Avatar
Well, Bismic helped both of us out there!
My temperatures, no load (Not hauling our Fifth Wheel) oscillate between 188 and 192 for Coolant and Oil when the truck is warmed up. In the morning there has been as much as a 7-10 degree split for the first 5 minutes, oil temp lagging coolant temp.
I drove to and from Acadia from New Hampshire with this condition. I was not aware of what the code really was until reaching Acadia, where a friend worked with me to install the Edge Insight I have now and checking FTE for further info.
My Degass bottle had been spitting, as it turns out, on the way to Acadia and then on the way back. This was caused, I am sure now, by the loss of additional cooling not being provided by the Fan Clutch due to its failure to "Step-Up". On the way back home, now monitoring temps with the Edge, I had reached 205-210 F coolant temp, maybe higher, on hills and grades. These temps rapidly decreased once cresting the hill or grade.
Although I was close to alarm points on several occasions, I got no more than a warning chirp from the Insight.
Short answer is yes, under load I am seeing higher temperatures. I hope to have that corrected next Friday.
Eric
Old 09-21-2011, 11:58 AM
Sounds like me. Empty i am seing 205-210 coolant temps. Sounds like my issues about to get worse! But my degas bottle hasnt been doing what yours is doing
Thanks bismic!
Old 09-21-2011, 01:13 PM
egregg57's Avatar
Thanks bismic!
I have the older Degass bottle cap (16 PSI). that one is being changed out today or Thursday for the new 20 PSI cap. Temps did challenge the 16 PSI releif on it and it would need to be changed anyway. It'll be interesting to see te result, if there is any!
Eric
Old 09-21-2011, 02:56 PM
Well let us know. I have the new cap to
Old 09-25-2011, 09:06 PM
egregg57's Avatar
Well the camping trip went well. With a surprise. I decided to wait on the degass bottle cap because when I went to the Ford dealer and asked for a new cap they brought one out that looked very much like the photos of the new cap But was still 16 Pei and not the 20 Psi that was referred to in the thread I was reading.
I had a little bit off spitting but nothing like before, on my way back from Acadia. Coolant is clean. Oil is new, just changed it. Towing temps ECT/EOT with in 5 degrees with the exception of hills where I could see a 10 degree difference with ECT being higher. 210 was Max ECT. here is the surprising thing...
At ECT of 210 the fan clutch kicked in and quickly dropped temp to about 195 before returning back to normal rpm.
The electric fan clutch worked just fine. The code P0528 Fan Clutch Sensor: No Signal, remains. So I am a little confused and am now going to go through disassembling the shrouds and inspect the harness a bit closer.
It is possible that when the clip broke the harness was slightly clipped and caught one of the wires for the sensor. The PCM is calling for the fan, the fan is response ding but can't talk to the PCM.
A much less expensive repair.
Hopefully this will help some one else along the line. Love my Edge...and my big 6.0!
Eric
Old 09-25-2011, 09:25 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Are you getting a P0480 along your P0528? If it's just a P0528 you're getting alone, it likely means your PCM is not reading the actual Fan RPMs, but still operational (which is the important part). If you were getting a HARD P0480 and P0528 together, I would say the fan blade ate the actual harness. The dealer level test of its operation, is to run the engine at 2500 RPMs STEADY. Take active command of FAN_VAR Duty Cycle from 0% to 100%, and fan speed should instantly rise to 2800 RPMs and beyond.
In the OP's case, if I were to guess, I would say that it would likely pass the above described test, but not indicate the FAN RPMs.
excessive running fan??? TK-Leather 6.2L V8 2 03-20-2015 07:47 PM
Electric Fan? For 04' 6.0 calvinbabb 6.0L Power Stroke Diesel 32 11-19-2014 01:27 PM
Fan Clutch Failing? Snow plow fan clutch? oldmanAZ 1999 to 2016 Super Duty 0 10-19-2014 12:02 PM
Electric fan gad4wd 2004 - 2008 F150 1 04-17-2013 05:46 AM
Electric Cooling Fan Vs Fan Clutch helpfulguy 1994.5 - 1997 7.3L Power Stroke Diesel 30 12-06-2012 04:04 PM
Tags
04, 05, 2008, 60, clutch, code, excursion, explorer, f350, fan, ford, p0528, sensor, signal, speed, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
