Pics of my truck today - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 09-20-2011, 07:31 AM
iwanaflattie iwanaflattie is offline
iwanaflattie is gaining momentum as a positive member of FTE.
Morning Jeff
Stupid people spaming or your cool thread.
I think that Dale and Ilya are talking about the metal strips that hold the boards down,But I guess you have the bed with the metal floor.
Correct me if Im wrong.
are you going to rock the long bed??
  #47
Old 09-20-2011, 07:36 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Quote:
Originally Posted by iwanaflattie View Post
Morning Jeff
OHHH!!!!! I need more coffee ! I was thinking RUNNING boards!
Ok on track now! Thanks Seth!
edit: and my bed had wood, there are 1" pieces left in the bed, leftover from a saws-all job.
  #48
Old 09-20-2011, 07:42 AM
And good morning to you sir!
Again more coffee needed, explain rock the long bed...i got my own thoughts..but...
  #49
Old 09-20-2011, 10:10 AM
Are you going to keep the long bed or are u going to shorten it.either way it looks cool
  #50
Old 09-20-2011, 10:23 AM
I'm going to stick with the longbed at this point. I don't want to deal with shortening the frame or shortening the bed, or a different shortbed or so on and so forth. I have thought about it and i go back and forth, but at least for now, it is what it is.
  #51
Old 09-20-2011, 03:50 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
Jeff, the front of my bed was also bowed out. I cut the spot welds and removed the entire panel to work on it. I had lots of shrinking to do (po hauled cinder blocks) and it was far easier to fix being able to lay it on a flat surface. You may have to remove the rolled top portion and replace it with tubing.
  #52
Old 09-20-2011, 04:44 PM
Quote:
Hi Rusty, I was planning on taking the bed apart to do that, how is the rolled top, on the front panel supposed to be attached to the sides or are they?
they have been welded and are cracked so i assume that's not right.
I was gonna take out the rivets and use a round headed bolt replacement. like a buttonhead bolt? I know you can buy new rivets but i don't have the equipment to install solid rivets. When I was in the aircraft division of the US Navy, we used soild rivets but they were aluminum.
  #53
Old 09-20-2011, 07:51 PM
james rich james rich is offline
james rich is starting off with a positive reputation.
hi jeff on sunday my dauter and i made what we call the loop 10 miles of back country roads. we pulled into drive the boss wanted to go give it a try WELL she has a lead foot 3 times she was told to slow down she said that it goes ok but the breks dont slow it fast enouh.we had good hour driveing the truck. jim and sam
  #54
Old 09-20-2011, 08:27 PM
Quote:
Hi Jim! That sounds like a good time to me! Glad to hear you got them out on the road(truck and daughter)!
  #55
Old 09-20-2011, 08:37 PM
cmoritz cmoritz is offline
cmoritz is gaining momentum as a positive member of FTE.
Looking good Jeff, .. the "mocking things up with a freshly painted frame" stage, should give any cold-blooded American Hot-Rodder enough fuel to follow thru to the end of a project....you are well on your way....for me, learning the smaller details of how the sheetmetal was supposed to look like finished..then learning how to do it, was the most rewarding part of my project..because I had NO idea what I was doing..and later it looked so good on the frame,..even in primer! One step (panel) at a time..
  #56
Old 09-20-2011, 09:11 PM
Quote:
I have done my share of bodywork and now its time to improve upon my experiences! Funny you mention bodywork...I was in the garage tonight shadow priming a rear fender and board sanding to see the low and high spots. Oh wow do I got some sheetmetal work to do! I like it cause it is so rewarding, as you said! I have been searching for some decent body hammer/dolly stuff and I want one of those shrinking disks! I want to use as little filler as possible. Thanks!
  #57
Old 09-20-2011, 11:48 PM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
I was just curious if you happen to have pictures or a thread about your IFS install. Love the thread though!
  #58
Old 09-21-2011, 12:04 AM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is offline
BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.
Hmmmm, so Jeff likes body work. Joe doesn't. Joe likes mechanical work and wiring. Jeff doesn't. Methinks there should be a labor swap arrangement in the works here!
It's looking good, man. Keep after it.
  #59
Old 09-21-2011, 07:45 AM
Quote:
I have some pics of my Jag IFS in my albums but I will be the first to admit...I am not real good with organization of them. Look thru my albums and I can take some for ya if you want.
  #60
Old 09-21-2011, 07:46 AM
But I never said I was good at it!
1956 COE Project Marcelof100 Large Truck 8 01-10-2017 10:36 PM
EGR delete Burdpete 6.4L Power Stroke Diesel 3 12-23-2015 04:13 PM
Show off those rims and tires. maverick600 1967 - 1972 F-100 & Larger F-Series Trucks 4 04-22-2014 09:19 AM
led dash light mod Kingkoopa 1994.5 - 1997 7.3L Power Stroke Diesel 13 02-11-2014 11:08 PM
97-02 expedetion seats in 92 v8xploder 1978 - 1996 Big Bronco 2 01-31-2010 12:46 PM
Tags
1994, 2003, 52, beat, beatup, f150, f2, ford, fseries, green, maroon, meadow, old, pics, picture, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
