Pics of my truck today - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-19-2011, 06:42 PM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
It's hard to say by the pictures but can you tell by looking (or placing the curved portion of the patch piece on top of your running board and see if the contour-curve of it will even match up well with the F1 rear fenders profile???) you may have been required to modify the boards anyway? if they werent already cut prior??
just wondering if you just so happened to have a set of original running boards if they would fit right anyway, without slight mods to the rear curved area??? what ya think
anyway, your day is running out, get off the computer and get back out there while its still light out..
  #32
Old 09-19-2011, 08:42 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Hey Josh, yeah I did take the patch with the rear portion and put it in place, it fits good to the fender and lines up well with the bottom of the bed. I may have to redrill holes in the brackets, but with everything loose, it's too early to tell. And I did expect some kind of rework back there but wasn't sure what.
I will take a pic of that in a while and post it here.
  #33
Old 09-19-2011, 09:10 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is online now
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
Hi to you both, I just viewd your alblum and can see how much hard work you have already put into your truck, so I just wanted to say good job and keep up the good work. Looks good.
  #34
Old 09-19-2011, 09:59 PM
Quote:
Thanks Jim! I have watched your success also, so congrats on getting 'er done!
If they are ever done!
Josh:
  #35
Old 09-20-2011, 01:41 AM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
JEFF i have some used bed strips in good shape if ya need them. ONES THATS HOLDS THE BOARDS DOWN. pm me.
  #36
Old 09-20-2011, 02:05 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Quote:
Dale, are they from the green F1? F2-F3 bed strips are longer than F1 bed strips.
  #37
Old 09-20-2011, 02:25 AM
stripes
Quote:
YES IYLA they came off the green 51 f-1
  #38
Old 09-20-2011, 02:33 AM
iwanaflattie iwanaflattie is offline
iwanaflattie is gaining momentum as a positive member of FTE.
Thanks pinthus????????
Jeff thats some good progress.keep it up.
Why dont ya fab your own RB??
Or get Ilyas and cut the damaged sides and weld in some tubing.?
You do nice fab work Im sure you can pull it off
  #39
Old 09-20-2011, 02:39 AM
I have one good and one that is bent on the edge can't remember which one is bent . F-1 51.
  #40
Old 09-20-2011, 02:49 AM
badger_hound's Avatar
badger_hound badger_hound is offline
badger_hound is gaining momentum as a positive member of FTE.
Keep at it Jeff! One piece at a time.
Quote:
Looks like a spambot...
  #41
Old 09-20-2011, 02:52 AM
Thats what I thought so I tried to be sarcastic lol.
didnt work.hahah
  #42
Old 09-20-2011, 02:58 AM
didnt work.hahah
Right on, made me look twice!
  #43
Old 09-20-2011, 08:10 AM
Dale,
Ilya, what are bed strips that hold the boards down?
My boards bolt to the bracket/arms under the boards and also bolt to the frame.
Either something is missing that I am unaware of, or something with mine is different?
  #44
Old 09-20-2011, 08:12 AM
didnt work.hahah
Yeah I was like huh?
You did pull off sarcastic!
  #45
Old 09-20-2011, 08:22 AM
Thanks Badgerhound! I started to straighten some sheetmetal at the back lower rear corner of the bed, down below the tailgate. I looked hopeless at first, and it actually is pretty straight now, not done completely, but better than it was. Not a perfect shot of it, but this corner. I got to figure out what to do with the rear of the bed. these corners have been welded and cracked, etc. bolts broke off...
I got to removed the R. rear stakepocket and work it over too.
Electrical Diagrams trike1946 1968-2013 Full Size Vans 1 01-19-2015 06:37 AM
Show off those rims and tires. maverick600 1967 - 1972 F-100 & Larger F-Series Trucks 4 04-22-2014 10:19 AM
What are some signs of injectors wearing out, or going bad? shark1979 1999 - 2003 7.3L Power Stroke Diesel 6 11-29-2010 04:10 PM
will 1970 351W heads work on my 1984 engine? gotjeepzj 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 51 11-11-2009 09:26 AM
Clark transmission JERSEYJOE2937 Clutch, Transmission, Differential, Axle & Transfer Case 8 09-08-2007 04:58 AM
Tags
1994, 2003, 52, beat, beatup, f150, f2, ford, fseries, green, maroon, meadow, old, pics, picture, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
