Truck just cut off and wont start?!?!?!?!
Hello I'm new to the forums but will be a long time member so welcome me. Anyways I have a 89 f350 7.3. I was crusing down i-95 when it just died. No stuttering just flat out died. I had a new fuel sending unit installed as well as glow plugs and various other things. It still wont start. I get nothing even when I spray a lil ether in there. It seems to be electrical. Is there something in the ignition that would not allow for it to start? I'm fresh out of ideas and so is my mechanic.
If you loosen one of the fuel lines on top of the injectors, does fuel dribble out?
Chec that the fuel shutoff solenoid on the injection pump is getting power with the key on(lower of the two wires hooked into the drivers side of the IP). If that shuts off, you won't be getting any fuel to your injectors.
EDIT: I see the problem's been fixed. Betting it was the FSS wire he 'wiggled'...
just trying to move the "said" wires around while its running to see if it will shut off like it did while I was driving.
pick1
20
01-29-2019 03:53 PM
gcfisher75
06-05-2012 09:16 AM
