Straight 6 sounds like diesel when warm
I have a 91 F150 with a 300 straight 6 in it. Recently I noticed that when it gets to operating temp the oil pressure drops and it sound like a diesel when i get to the end of a gear or feather the accelerator. It has 250,000+ on it. Could this old girl be getting to tired?
Probably rod bearings. Rod bearings just getting a bit too worn can do what you describe. Low oil pressure is also consistent with worn rod bearings. (or any bearing for that matter). Main bearings will typically make a scratchy screeching noise, rod bearings usually knock.
If it is rod bearings and you replace them quickly before it gets any worse, they may be all you would have to change. If you keep letting it knock, it will start to hammer the crank out of round. Eventually you'll hammer the rod cap right off and your engine block will have a new hole in it.
However, start with the basic stuff. Let it get warmed up, and then take the serpentine belt off and take it for a quick drive (before it has a chance to overheat) to eliminate any accessories that could possibly be making the noise. If the noise goes away with the belt off, than you know its one of your accessories making the noise.
no one knows for sure what it is , the lifters are one of the first things to clatter and with no or low oil pressure a new pump can fix that !
now as for the rods plastigauge will tell how much clearance and nothing else ! if the rods knock even a little the will hammer the journals and make them out of round and you cannot see out of roundness with the naked eye !
like i said it is a wast of time and money to new bearings on old and wore out parts !
Katmandu
08-03-2004 01:31 PM
unioncreek
02-07-2002 01:29 PM
