Fuel pump trouble 1991
My truck quit on me out of the blue while sitting at a traffic light tonight. I noticed when i tried to restart it that i wasnt hearing the fuel pump turning on like it always did. The only thing i have done so far is check over the connections under the hood also checked to make sure there was pressure at the fuel rail which at the time there was. After about 20 minutes i did get it to fire up long enough to get out of the middle of the street. Can anyone get me started on what to look for? I dont have access to a computer or i would have already searched the forum,for some reason this phone wont let me do that so im kinda stuck. Once it stops raining im going to hook my code reader up and see what i come up with but ive never had any luck at all with it. Give me some ideas.....
Ok code reader says 11,10,41,33....also i heard the front pump kick on and there is now pressure at the motor. B4 i hooked the code reader up i moved the wires around by the starter solenoid looking at the fuseable links i heard one of those goes 2 the pumps? Any1 know? Soon as it quits raining again im gonna go give it a try...
Code reader says 10,11,41,33....when i turned the key on to run the reader test the front pump worked and i now have pressure at the fuel rail. I did move the wires around by the starter solenoid to see if the fuseable links were ok b4 i run the test. I heard one of those wires goes to the fuel pumps any1 know? Soon as it quits raining again im gonna see if it will at least start.
RanB
06-16-2018 07:26 PM
dno1
04-22-2010 08:16 PM
randinow
1997-2006 Expedition & Navigator
01-08-2010 11:09 PM
