Is it a turbo hiss?
#32
#33
OK i drove it and still no umph. I can hear the turbo whistle but still no get up and go. It is very responsive in neutral, I can mash the pedal and motor tries to flip out of the mounts. As soon as i put in drive and mash the pedal. Forget it! a Uhaul in reverse will smoke me. I check with another code reader. Nothing stored. I dont get it it ran better when I had the leak on the ypipe. Sure it had no bottom end but once I got to bout 30 I was gone like a set of rims at a puff daddy concert ( thanks cable guy).
#37
@partsman I have strong fuel pressure
@ blade I have the metal tubes. i thought i had an air leak to but today i got home unbolted the elbow from intake and I had boost in neutral. Not sure how strong it should be feeling it by hand but it felt strong. i am starting to lean towards vgt gone bad. Took it for a drive with it disconnected and truck acted the same.Now being just an old school back yard mechanic, I was curious if I was getting any voltage to the solenoid but when i connected it back up I noticed a different tone to the motor when connected and disconnected.I do not have a volt meter any more my rotty thought it was a chew toy
#39
#42
#43
GOOD NEWS... the EBP hose was clogged some where in the middle. I replaced the hose(well i cut it off my 82 collectors edition vette...wife is gonna kill me) and now the truck is smoking the wheels again. I was gonna remove the sct and take it to the stealership but NOPE!!! aint happening...
