knocking 5.4 not piston slap - Page 2 - Ford Truck Enthusiasts Forums
Old 10-04-2011, 01:53 PM
TheWhiteBeast TheWhiteBeast is offline
TheWhiteBeast is gaining momentum as a positive member of FTE.
As mentioned before it can be A. Worn out chain guides/tensioners or B. When spark plugs are getting ready to blow out or have become loose, the compression getting past the spark plug will make a ticking sound. Make sure all of your spark plugs are torqued to factory specs. Blow outs are NO FUN!
Old 10-04-2011, 06:49 PM
vaper vaper is offline
vaper is starting off with a positive reputation.
Thanks for all the suggestions,I to fordman am pulling the front cover next.If new chains, guides and tensioners don't do it,off comes the oil pan.
Just put in a fresh set of plugs a month ago and had them out again when I did the lash adjusters (didn't want to drop a valve).
Good luck fordman let us know how it went.
Old 12-20-2011, 05:06 PM
Bundy34 Bundy34 is offline
Bundy34 is starting off with a positive reputation.
Any update on this? I have a very similar noise.
Old 12-30-2011, 06:19 PM
I haven't gone any further than a set of lash adjusters yet.I really think I have a lot better throttle response since the change.
I am curious as well how 78fordman made out with this.
Old 12-30-2011, 09:01 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
actually i traded it off for a e-250. I mentioned it to the salesmen and he said they all do it ??? My 02 e-250 has a 5.4 and sounds nothing like my 00 did.
Old 12-31-2011, 12:57 AM
Hotpocket's Avatar
Hotpocket Hotpocket is offline
Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.
my 5.4 has a very quiet version of this sound
Old 12-31-2011, 10:55 AM
Mine started out as a faint noise about 20,000 kms ago Hotpocket.
Did you get a fair dollar for the trade in Fordman?
Old 02-16-2012, 07:28 AM
dire straits dire straits is offline
dire straits is starting off with a positive reputation.
Question
Quote:
Originally Posted by 78fordman View Post
mine is only at 1000rpm and under. While driving down to road or even reved up with no load it is quite. I have no codes but i am going to get a couple of tensioners and guides and see if it is some chain noise.
Fordman did the tensioners and guides fix the noise? I have the exact syptoms in my 04 5.4L 2v.
Dave
Old 02-16-2012, 05:08 PM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
i have the same noise but not as bad as that video
Cold Ford 5.4L - YouTube
Old 02-16-2012, 10:20 PM
96f150's Avatar
96f150 96f150 is offline
96f150 is starting off with a positive reputation.
My 01 sounds just like your 2003!! awsome footage by the way!! mine has done it since I got it used with around 85k on it, I now have 125k on it, I have attributed it to the short piston skirts making the piston slap noise. It goes away once the trcuk is warmed up a bit.
Old 02-16-2012, 10:21 PM
acf6's Avatar
Yeah I bought mine with 35k and its still doing it at 55k. Went away slightly with Valvoline durablend and when its fully warmed up I don't hear it at all
Old 02-16-2012, 10:55 PM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Quote:
Dave
U have a complete different horse there.don't get mixed up in this conversation cause your 5:4 is different
  #28
Old 02-17-2012, 06:37 AM
Thumbs up
Thanks, Fordman
  #29
Old 02-17-2012, 08:09 AM
Ironhand03 Ironhand03 is offline
Ironhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputation
Quote:
If that was the issue then almost every stock 4.6, 5.4, and 6.8 would have issues since they all use the same pistons.
I will say it can obviously be different things depending on the engine. But a slap noise, I would guess is the chain guides/tensioners. A light tapping noise could be a solid lash adjuster or an injector.
  #30
Old 02-17-2012, 08:49 AM
96f150's Avatar
It was a well known issue since the triton's have been introduced...tolerances of course will vary with castings
Knocking Sound Coming from the engine Tamtamk Expedition & Navigator 5 11-03-2016 04:45 PM
Knocking from bellhousing area Slogeris30 Connecticut Chapter 3 11-22-2015 08:04 PM
5.4L 3v Camshaft Phaser Knock Noise Fix makuloco2000 2004 - 2008 F150 6 09-07-2015 05:23 PM
Very Loud knocking noise on cold start up acate76 2004 - 2008 F150 2 06-22-2014 02:39 AM
4 times in the shop...still the same problem 460k&n 2004 - 2008 F150 1 04-18-2010 10:17 PM
Tags
1996, 1997, 54, 99, explorer, ford, forged, idel, knocking, low, noise, piston, ranger, rebuilding, slap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
