Toyota p/s with a 460
Old 09-18-2011, 07:21 PM
Englishbob's Avatar
Englishbob
Englishbob is offline
Anyone used a Toyota p/s steering box with a 460 in an F1-3?
I'm trying to keep the drivetrain low but have header clearance problems.
Anyone figured a way?
Thanks
Bob
Old 09-18-2011, 08:32 PM
JBjorgaard's Avatar
JBjorgaard
JBjorgaard is offline
Can't find the link where I saw it....
The general idea is that you cut the web on the frame rail and weld an offset box to move the steering gear to the outside and inch or so.
Old 09-18-2011, 09:03 PM
Dano78's Avatar
Dano78
Dano78 is offline
What about moving the engine over an inch or so to the passenger side? Is the F1 frame narrower than the '53-'56 F100s? Can't imagine trying to run a Toyota box with a 460! It was tight enough with the FE and I'm not sure which engine is wider! I didn't offset my FE but hindsight says i should have... I'm pretty tight to the box in my '56.
Old 09-18-2011, 09:10 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
F1's frame is two inches narrower overall in the engine bay than the '53 and newer.
Old 09-18-2011, 09:19 PM
Dano78's Avatar
Dano78
Dano78 is offline
Wow! You've got your work cut out for ya then!
Old 09-18-2011, 09:26 PM
Englishbob's Avatar
Englishbob
If they make headers like that for a 460 I might be ok.
Old 09-19-2011, 09:03 PM
Dano78's Avatar
Dano78
Dano78 is offline
The car manifolds on the 460 fit pretty snug to the block. The manifolds i have on my FE are garbage. Pretty much like crappin through a coffee straw. They have no flow to them what-so ever hence why they are nick-named 'log manifolds' as they are no different than a simple 2x4 chunk of wood with holes in it. If i could run headers, i would in a heartbeat. Best thing going for them is that they have a 2.25" outlet versus the 2" outlet you ypically find on the FE manifolds. The 460 manifolds are typically 2.25" outlets with the truck manifolds being the exception being 2.5". Probably be a trial and error situation... i know they do make block hugger headers for the 460. Can't remember the manufacturer, but I do recall seeign a set or two.
Old 09-19-2011, 10:20 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Bob,
I found this link that discusses the trials & challenges of fitting headers onto a 460 in our trucks - maybe there is some information that might help. I know Sam (Sdetweil) spent a lot of time researching the different header options before finally going with customs to get it all to fit on his '55.
Good luck over there.
Ben in Austin
https://www.ford-trucks.com/forums/9...lare-clip.html
F-250 restorer
15
08-30-2019 11:39 PM
007brian
03-02-2015 08:29 AM
CharlieLed
21
10-24-2007 12:10 PM
OzFTrucker
07-09-2006 08:44 AM
chromedaddyo
03-17-2004 11:56 PM
Quick Reply: Toyota p/s with a 460
