55 kept trying to start without key and now there's no power. - Page 2 - Ford Truck Enthusiasts Forums
Old 09-19-2011, 01:18 AM
DumbLuck's Avatar
DumbLuck DumbLuck is offline
DumbLuck is starting off with a positive reputation.
maybe these will make things clearer for the stock starter setup. One these should be what you're dealing with I should think. I believe it was "Julie" that originally posted these.
Old 09-19-2011, 01:27 AM
DumbLuck's Avatar
who checked your battery, and how did they do it? if it was the pimply faced kid at the auto store he might be clueless. I can't count the number of times I've heard people insist the battery was fine only to have it be badly discharged. Did you put it on the charger after the problem occurred? A bad ground connection can mimic a dead battery too. Are the terminals clean and where the battery cable attaches to the the truck's frame good?
Quote:
Originally Posted by fordmanforlife246 View Post
Without my key I'n the truck I could push the starter button and it would crank the engine but not start it untill my key was In. So what I
think might have happend was the starter button was
stuck and it blew a fuse or a wire went bad from the consistent amps. But then the truck had no power after that, that's why I am confused. I even took the battery to get checked for amps and volts and they said it was good. So then I replaced the solonoid and still no power
Old 09-19-2011, 06:56 PM
fordmanforlife246 fordmanforlife246 is offline
fordmanforlife246 is starting off with a positive reputation.
Okay guys I got an update! So I hooked my battery back up and I turned my key an I had power! I even had power to my wipers and air conditioning which haven't worked I'n a while! So then I go to push the start button and I lose total power an I have to reconnect my hot wire to get the power to start again. What the heck?
Old 09-19-2011, 07:01 PM
wmjoe1953's Avatar
wmjoe1953 wmjoe1953 is offline
wmjoe1953 is gaining momentum as a positive member of FTE.wmjoe1953 is gaining momentum as a positive member of FTE.
Bad connection some where. Check all the connecting points of the ground straps, and battery cables. My 1991 F-250 does that exact same thing, I need to wiggle the battery cable to get it to start. I haven't gotten around to new cables yet, as I know they are no good.
Old 09-19-2011, 10:13 PM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Yep.. You definately have a short/grounding issue. Ensure that you have good engine to frame, and frame to body grounds. Not just some wimpy wire, but good cable sized stuff. Make sure the soleniod is mounted good and tight and that the mounting ear has good contact with metal.
Sounds like you probably have a 12V neg ground system, since you mention having A/C. Good grounds are key to having any electrical system reliable.
Old 09-19-2011, 11:00 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
when that happens to me, its usually the main ground cable on the battery. Do you have any of those cheapy battery end clamps that have the bolt down crimp? if you do, throw that junk away! Oh i don't know how many times I have had to deal with those! I hate them! ok well maybe HATE is too strong, but...
Old 09-20-2011, 01:02 AM
Alright guys well I went and got the battery tested again! And the battery had no amps so the battery was no good!
Old 09-20-2011, 09:43 AM
49fordpickumup's Avatar
49fordpickumup 49fordpickumup is offline
49fordpickumup is gaining momentum as a positive member of FTE.
Back to day one. You again had a good system until you engaged the starter. I think maybe either the wire between the solonoid and the starter maybe shorted to the frame,engine or starter case or the starter may have a internal short. Please don't install a new battery and attempt to start again without repairing the problem. chuck
Old 09-20-2011, 10:08 AM
DumbLuck's Avatar
This thread is becoming a good argument for a battery cut-out switch. I also noticed that in the '53-'55 stock wiring that there is no breaker or fuse between the hot power lead from the battery side of the solenoid all the way thru the amp meter, to the breaker on the back of the instrument cluster. And that breaker automatically resets on it's own. Finding some sort of fuse to put in that line close to the solenoid is on my long list of things to do.
Old 09-20-2011, 10:45 AM
heavyhitter 460 heavyhitter 460 is offline
heavyhitter 460 is starting off with a positive reputation.
Quote:
that's what i'm thinking. cable from solenoid to starter is fried. if the truck was trying to start continuously it had to cook something between the battery and the starter.
this is just a symptom of the original problem, though. you started with a bad switch or a short somewhere related to that switch.
i'm betting you have the original problem plus everything caused by it.
Old 09-20-2011, 11:26 AM
I had my starter tested and it is good. I'm thinking it did that because the solenoid was arced. But I will check up on the cables
QUOTE=49fordpickumup;10829800]Back to day one. You again had a good system until you engaged the starter. I think maybe either the wire between the solonoid and the starter maybe shorted to the frame,engine or starter case or the starter may have a internal short. Please don't install a new battery and attempt to start again without repairing the problem. chuck[/QUOTE]
Old 09-20-2011, 06:27 PM
wilsel's Avatar
wilsel wilsel is offline
wilsel is starting off with a positive reputation.
I agree! I had a similar problem, and it was because the positive starter cable terminal was arching to the block. It was about 1mm from the block, and did not present any problems for a long time, until 1 day.
Starter not disengaging brookdale79 1973 - 1979 F-100 & Larger F-Series Trucks 14 01-18-2015 04:26 PM
PATS Magic, Again......Suggestions, Please DSMMH 6.0L Power Stroke Diesel 10 12-24-2014 07:21 AM
1980 F100 turn key, won't start then everything dies. Uncle Paul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-22-2014 10:33 AM
starter won't disengage Singing River Farm 1994.5 - 1997 7.3L Power Stroke Diesel 18 01-25-2014 04:51 PM
Weird starter issues... Please help BRay09 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 31 06-21-2011 01:14 PM
Tags
f150, ford, key, start, truck, trys
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
