Pertronix 1281 trouble - Ford Truck Enthusiasts Forums
Old 09-18-2011, 05:17 PM
JimG1098's Avatar
JimG1098 JimG1098 is offline
JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.JimG1098 has a great reputation on FTE.
Hi gang.
Installed Pertronix 1282, and flamthrower coil ( 1.5 ) in early May. Truck started right up. ( 54 ford, 279 ci ) Truck is not on road yet but start it up weekly . Last Sat, Truck was at Idle, and just quit. After doing usual trouble shooting, no spark from coil.
Called Pertronix, they gave me a few additional checks to do. Then thay said to send both pieces back. When it died, the coil was so hot I could not touch it.
Has anyone experienced trouble with the pertronix units, ( 1282 ignitor, flamethrower coil ( 40,000 v ) If so, what was cause of trouble and what was remedy
thanks crew. ( when this happerned I was just so deflated. Everything was going well, ( slow but well )
JimG 1098
Old 09-18-2011, 06:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Back about 7 years ago, Pertronix 6v units were notorious for failing regularly (usually at night and on a dark highway 20 miles from anything). They made some changes, from what I heard, and I haven't heard much since, but almost everyone went to 12v or stayed with points if on 6v.
The generator regulator cutting in and out puts severe spikes into the electrical system as the regulator points arc. It fries a lot of modern electronics. If you stick with 6v and Pertonix, I'd consider adding a filter in the wiring to the ignition, like used on car stereos. Usually a big inductor and capacitor to smooth out/absorb spikes.
Old 09-18-2011, 07:12 PM
larryb346 larryb346 is offline
larryb346 has a good reputation on FTE.larryb346 has a good reputation on FTE.
On most of the old vehicle forums, cars in the 30's to early 50's, the opinion is throw the electronic ignitions away and stick with points.
Pertronix has had, and likely will continue to have, problems with their 6 volt stuff. The early ford forum and several GM forums have discussed this same issue in hundreds of post.
I'm old and am very comfortable with the points and keep in mind these old trucks were driven across country, thousands of times, just like they came from ford. I have put 14,000 miles on my 46 mercury since I have touched the distributor and have points in the 302 in my 55. I am not talking about any electronic ignitions in 12 volt but in 6 volts the vast majority of people seem to end up having issues.
Am sure that's not what you wanted to hear but is my opinion anyway.
Like everything else in life opinions will vary
Larry
Old 09-18-2011, 07:54 PM
JimG1098's Avatar
Thank you guys. I neglected to say that my truck is a 12v system, But I so appreciate you coments. Since my post, I have been online checking this type of failure out. Seems quite coimmon even on the 12v systems.
Reports of the coils getting so hot We'll kiip looking and wonder what Pertronix will have to say. ( hope they give some sort of explanation) Dont want it to happen again with the replace units.
Jim G 1098
Old 09-18-2011, 08:31 PM
ALBUQ F-1's Avatar
postin' fool
It is relatively easy to retrofit a stock dizzy to use electronic components. Depends if you are a machinist or have a friendly local guy to chuck up the pieces. MSD and others sell complete distributors that seems to be trouble-free. See the recent thread on ProComp distributors.
Old 09-18-2011, 09:18 PM
I had looked at the 1282 number you listed and it showed to a 54 to 56 Y block and it would be for 6 volts. If that's the one your using and it's on 12 volts that might be you issue
Old 09-18-2011, 09:42 PM
JimG1098's Avatar
Sorry, fat fingers in typing part is a 1282, 54-56 y block, 8 cyl. goof in orig post
Old 09-18-2011, 11:23 PM
ALBUQ F-1's Avatar
postin' fool
Pertronix 1282 is apparently available in both 12v and 6v; which do you have?
Old 09-19-2011, 06:26 AM
JimG1098's Avatar
12 volts system.. If you order a 6v one, the part number has a 6n or a 6p added to itm accorting to the web site, sub note 55, 56
JimG 1098 build of the 54 F-750 Fire Truck JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 222 01-04-2017 06:00 AM
Hood hinge assistance. JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 05-06-2015 06:53 AM
bleeding bakes, a little trouble JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 04-28-2015 07:23 PM
PerTronix Ya or Na? ilovegamesandcars 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 12-03-2013 08:06 AM
Pertronix Install problem. Wrong part #? stinkfist Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 03-19-2005 11:48 AM
Tags
1281, 1282, 1960, 279ci, 368, 370, bronco, coil, ford, hot, pertronix, petronix, thunderbird, troubles, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
