Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-18-2011, 02:42 PM
richdawg's Avatar
richdawg richdawg is offline
richdawg has a good reputation on FTE.richdawg has a good reputation on FTE.
Glow Plug Switch Question????
To switch the GP's I cut the small red wire on top and run the switch wire inside the cab, correct?
I got a little confused yesterday, I had both wires totally disconnected and when I turned the key to ON the wait to start light came on and the amp gauge still dropped as usual (like GP's were still on. Click the image to open in full size.
__________________
Rich-97 F350 SC Dually long bed 2wd, 5 speed, 410's, 145000 : 6637 intake filter, Tymar 3" down pipe, cat delete, IDM 140v, Digital pyro gauge, Rosewood Stage 1's, FPR shim, CCV mod. Valair 400 HP Organic Clutch, GPR manual momentary switch, Superchip 1700 tuner/programer.
To do would be install 6.0 intercooler (need pipes and boots)
Old 09-18-2011, 03:36 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Whichever wire that goes to the PCM is the one you splice IIRC.
Then throw a relay in the middle.
Going from memory.
Was tempted to do this long ago, just never got around to it. To many other projects.
__________________
Talyn (AKA: der Schafen Führer)
1994 F250 XLT 4x4 Standard Cab - T-444E Direct Injection Turbo Diesel, 5 SPD M/T Z/F S5-420, Rosewood 160cc Stage 1's, PHP Tuner, 6637, Short Throw Shift Kit, Valair Kevlar/Ceramic, 140V IDM, T-500, 285/75/16 Cooper Discoverer ATR. Steyr C9-A1.
You can get more with a kind word and a 2x4 than you can with just a kind word.
Old 09-18-2011, 04:06 PM
Hussler's Avatar
Hussler Hussler is offline
Hussler has a great reputation on FTE.Hussler has a great reputation on FTE.Hussler has a great reputation on FTE.Hussler has a great reputation on FTE.Hussler has a great reputation on FTE.
If you want to disable the GPR you can use either small wire to go to the switch and back, probably best to use the purple wire though. Red wire is hot all the time, from fuse #22 and purple wire is pulled to ground by the PCM to activate the relay. WTS light will always come on regardless because it is a different circuit in the PCM. Don't understand why AMP gauge doing what you are describing (both wires disconnected, or even 1) unless the GPR is shorted internally and a test light or voltmeter will troubleshoot that.
__________________
Jim
1997 F250 HD CC 4x4 7.3L - E4OD - 3.55's
Napa 6637 - FPR Shim 3" Down Pipe & CD 203 Stat
Riffraff
HPX - Interceptor Scan Gauge - Cobalt Digital Pyro
Old 09-18-2011, 05:22 PM
richdawg's Avatar
Thanks for the reply's I'll use the purple wire for switch and do some testing on the GPR.
__________________
Old 09-18-2011, 10:04 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
If that doesn't work for you Rich I can look at mine and see how I did it and report back. I can't recall now because of gray matter. lol After the first start of the day I flip mine off. It just bugs me to see them run all the time when I just do short trips.
__________________
Glenn The Mule-96 2WD F250 EC/LB auto PSD
The Mare 97 dually cc,modified s366 turbo,stage II's,IC,studs,springs,rods,JW auto,4:10 LS,air bags,SD uvch,efuel,FS2500 bypass oil filter,HVHF IDM,IH WP,6.0 trans cooler & rad fan,MBRP 4",SD tensioner,AFE air filter,220 amp alt,38 gal rear tank & 33 gal aux bed tank,aux oil cooler,soundproofed,3 different TS chips,ac cold mod,XS batteries,riffraff hpop reservoir,aluminum radiator,HoneyBadgerJr hpop, water injection
Old 09-19-2011, 01:32 AM
PstrokeN's Avatar
PstrokeN PstrokeN is offline
PstrokeN is starting off with a positive reputation.
i heard you can run the towo littler wires to a switch in the cab and when you hit the switch they come on????
__________________
97 F-250 auto with trans cooler and fan,3in DP straight piped, auto meter trans gauge in dash boost and egt in pillar,after market inner cooler,ball hitch in bed, 6637 mod,ccv mod,225/70/19.5s,315/75/17s,210,000
Old 09-19-2011, 08:01 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is online now
DIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to all
Quote:
You just need to run the purple wire into the cab. The PCM grounds the purple wire to turn the GPR on so if you ground that wire through a switch you can turn them on yourself, or if you want to disable them all together you just break that wire's path back to the PCM so the PCM cannot take the wire to ground.
__________________
--Nate "Just a redneck geek"
1997 F-350 7.3 PSD, 4x4, CCLB SRW, 3.55's, ZF5
If it isn't under warranty, I'll fix it myself.
Old 09-19-2011, 10:40 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is online now
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
You can also take the purple wire off and run a fused wire from battery to a toggle then to the relay post the purple wire came off of. Maybe i miss under stood your question though. This Method bypass the pcm.
__________________
Gabe 95 f250 4x4 super cab psd, zf 5 speed, 6637 air intake, scan gauge, stancor gpr, ccv mod, 140v IDM, HPX line, irate t4 mount, s366 turbo, i/c, 3" plenums, Rosewood 238/80 hybrids, T500, studs, springs, rods, DP Tuner f6 chip, diamond eye ss 4" exhaust, 3" dp, irate e fuel, short throw shifter, Valair kevlar/ceramic clutch, Destination MTs, d60 RSK V codes , shackle flip B codes, bilstien shocks, scorpion bed liner, custom tailgate. 96 f350 4x4 psd, dually flatbed welding truck, zf 5 speed, stock. 79 bronco.
Old 09-19-2011, 11:59 PM
madpogue madpogue is offline
madpogue has a very good reputation on FTE.madpogue has a very good reputation on FTE.madpogue has a very good reputation on FTE.madpogue has a very good reputation on FTE.
The unasked/unanswered question is - does the OP want to override the PCM and turn them OFF (when the PCM wants them on), or override the PCM and turn them ON (when the PCM wants them off)? If the former, then s/he'll need to interrupt (cut) the purple wire on the relay and put a switch in SERIES. Switch open -> GPs off. If it's the latter, s/he'll need to put a wire on the purple wire terminal, and run it to a switch that switches to ground, so it acts in PARALLEL with the PCM. If s/he wants both, then a three-position switch, incorporating both of the above, is in order.
Old 09-20-2011, 03:15 AM
richdawg's Avatar
OK: I just want to be able to manually turn on the glow plugs when I want or need them on. I think I will save some wear & tear on the electrical system. The GP's & Stancore Relay were new last fall. I have purchased a momentary switch that will return to off when not holding it in the on position.
I was testing things a little today and found that if I grounded the purple wire the GP's were off, but there was still more current draw on the amp gauge than I expected. Also if I need to fuse it what size fuse should I use?
__________________
Old 09-20-2011, 07:19 AM
Quote:
Only if you intend to run the wire to the negative side of the battery. The Red wire is hot all the time as was stated above (hussler) and the PCM take the purple wire TO GROUND to engage the GPR.
Quote:
This is what the OP wants to do according to his reply below.
No fuse is needed as the wire you are running is a Ground and the positive coil wire is already fused. So take two wires from your momentary switch, attach one to the terminal of the GPR where the purple wire formerly was attached (take the purple wire off the GPR) and attach the other wire from the switch to a good ground. Just tape off the purple wire good and tie it back out of the way (or leave it dangling there somewhere). Press the momentary switch (grounding the negative coil terminal of the GPR) and the GPR turns on the GP's. Smile, and consider for a moment how much better a job you do of glow plug management than the PCM does.
__________________
Old 09-20-2011, 11:20 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Wink
Quote:
One comment: as mentioned, both of them work, but if you use the red wire (hot) it lets the PCM turn off the glow plugs if you leave them on.
The way with the purple wire (ground), you have total control over the glow plugs and as long as the switch is on the glow plugs are activated. If you leave the switch on for two hours the glow plugs are on for two hours.
So, pick the one that is best for you. As I dont trust in my memory I use the hot wire.
__________________
96 F250, E40D, 2WD, 3.55, 145K. DIY intake-exhaust brake. DP 3-3.5" ceramic coated; HPX; GPR switch; Isspro gauges; shim FPR; Tru-cool; CCV mod; 4" SS exhaust; SS 5" tip; no cat; RacerX VB; TW 6p chip; 203*;140IDM;6.0IC; cristal clear lenses; fuel tank mod; AC cold mod; coolant filter.
«Primum non nosere» Drive safely !
Old 09-20-2011, 03:08 PM
Yes but breaking the hot (red) wire only enables you to turn OFF the GP's when the PCM is calling for them to be ON. Using the purple wire and a momentary switch (only stays on as long as you keep pushing it to the on position and returns to off as soon as you let go) you can turn them on and off any time you wish and they stay off any time you aren't pushing the button.
__________________
Old 09-20-2011, 03:53 PM
richdawg's Avatar
I don't trust my memory much anymore either (to much gray matter) that's why I'll go with the momentary switch,
I'll let ya all know how it works when get it done.
Many thanks to all that replied.
__________________
Old 09-20-2011, 04:04 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L BIGRED 7.3L is offline
BIGRED 7.3L is gaining momentum as a positive member of FTE.
Richdawg, if possible take some pics and write it up. I would like to see it for sure.
__________________
James-St. Louis
2015 F150 Lariat SCREW on order! 1996 F-350 Powerstroke OBS-Sold, 1953 F100 Panel 50th anniversary, 1957 F100 Custom Cab -Sold, 1968 Chevy II SS
[http://s1142.photobucket.com/albums/n611/bigred73/
"Life is hard; It's harder if you are stupid"-John Wayne.
Similar Threads
push button switch for GP's nick c Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 03-19-2013 07:10 PM
wiring diagram for 84 6.9l with manual GP switch maxride Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 08-01-2011 05:13 PM
1987 350 glow plug advice cdv10 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 06-06-2011 03:17 PM
DIESEL RANGER montana_highboy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-17-2011 10:45 PM
ignition is off & 7.3 glo plug lead wire are 12v blixx003 1987 - 1996 F150 & Larger F-Series Trucks 0 03-27-2011 06:54 PM
Tags
1996, 200, 73, 73l, f350, ford, glow, key, manually, mod, plug, plugs, relay, switch, turn, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
