Glow Plug Circuit fault P0675? - Ford Truck Enthusiasts Forums
Old 09-18-2011, 01:24 PM
TomCat-F350 TomCat-F350 is offline
TomCat-F350 is starting off with a positive reputation.
Does anyone know if this means glow plug failure or gp module or relay failure? It is on the #5 cylinder. Also can anyone direct me to where the relay and module are or what tech bulletin has the info? Thanks in advance
Old 09-18-2011, 02:23 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
more info what year ect.....
the GPCM is on passenger side valve cover
Old 09-18-2011, 06:40 PM
Thank you I found it. Do you know if this code is glow plug or module?
Old 09-18-2011, 07:23 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
PO675 is Cyl #5 glowplug circuit open.
Here's the full list:
http://www.dieseltalk.com/support/DTC.pdf
Old 09-19-2011, 12:00 AM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Disconnect the four-wire connector to the passenger side glow plug harness (the one with the red lock tab). Using your ohm meter (and the appropriate scale if it doesn't have the auto-range feature), connect the black lead to the passenger side negative battery cable and the red lead to each of the four cavities on the glow plug harness end. You should obtain readings between 0.5 to 2.0 ohms on all four circuits (cylinders #1, #3, #5 and #7). If all four yield similar readings, the cause of your P0675 is either a high resistance/open circuit in the main engine harness between the glow plug control module and bank #1 glow plug harness, or the glow plug control module itself (most likely scenario). If you do obtain either a high resistance or OL reading for cylinder #5 glow plug circuit, replace the glow plug harness on that bank (because it will ALWAYS break during removal no matter how careful you are) as well as cylinder #5 glow plug (or cylinders #1, #3 and #7 as well since you have the harness removed). If diagnosis determines #5 glow plug/ciruit faulty, remove the passenger side inner fender to gain easy access to the glow plugs and its wiring.
Old 09-19-2011, 10:43 AM
WOW! Great information and assistance!! I hope it is just the module as it is the easiest fix for this novice to working on diesels. Runs great if i plug in the cord for a couple of hours. It is a 2005 F-350.
Old 09-26-2011, 03:56 PM
Is this really something I can do or is it a"bite the bullett and take it to the dealer"? I have never done it before.
Old 09-26-2011, 04:26 PM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Others have done it.... it's just a PITA! Depends on how much "muscle tone" you've lost over the years!! LOL
Old 09-26-2011, 04:45 PM
I guess i could just keep plugging it in before i drive it cuz it runs great if the block is warm. Starts quick and runs great (now that i have a great tune in her) when it is warmed up. It just keeps nagging at me like my ex-wife. Ha!
Old 09-26-2011, 06:27 PM
Sullid01's Avatar
Sullid01 Sullid01 is offline
Sullid01 has a good reputation on FTE.Sullid01 has a good reputation on FTE.
TomCat - I am a regular guy with not much experience fixing trucks. I had a similar problem - #8 glow plug. I replaced the GPCM myself - that is easy - hardest part is wrestling with the boost tube to get it out of the way. It is easier with stock tubes (mine are aftermarket). It turned out to be the glow plug itself. I never got around to doing this myself - like you, I put it off for 4-5 months, then when something else broke, I had them fix that too.
Good luck!
Old 09-26-2011, 10:18 PM
Was that glow plug fix expensive? I changed the GPCM myself and like you said it was pretty easy. If it is too much i will have to just keep plugging it in before i have to use it. A bit of a hassle but money is money and if it ain't there it ain't there. Sounds like a Yogi Berra line. Ha
Old 09-27-2011, 12:47 PM
Sullid01's Avatar
the glow plug fix was reasonable - glow plug was $10 and one hour labor. The harness was not broken luckily (probably b/c I have a low mileage truck) - it gets brittle with age. It would be more if that needs to be replaced, probably 2 hr labor and $150 in parts (harness and 4 glow plugs).
Old 09-27-2011, 01:02 PM
Wow that is not bad at all. I wish i was in FL. to get it done that cheap. Dealers in Texas tend to rape its customers on price. I need to find a mechanic that wants the extra money on the side to do it. I may be able to get it done at FL. rates that way. Ha Thank you for your assistance with this.
Old 09-27-2011, 02:24 PM
Sullid01's Avatar
I buy the parts at Tousley Ford online (saves a lot of money). They charge $95/hr which I don't think is cheap, but they get things done quickly (less hours) and properly, so it is worth it.
Old 09-27-2011, 07:30 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
hey tom I got your info.. ill give you a call a little later my phone is dead waiting for ti to charge
Testing Glow Plug Module Oldguyfl 1999 - 2003 7.3L Power Stroke Diesel 8 02-02-2016 02:23 PM
glowplug module testing? Mr. Finch 1999 - 2003 7.3L Power Stroke Diesel 3 09-20-2015 03:10 PM
how to check glowplug module & glow plugs cope1972 6.0L Power Stroke Diesel 5 11-21-2014 10:17 PM
glow plugs croweyes 1999 - 2003 7.3L Power Stroke Diesel 1 11-12-2014 04:32 PM
Glow plug relay wires lancekilgore 1999 - 2003 7.3L Power Stroke Diesel 7 12-12-2012 11:43 AM
Tags
03, 60, 73, circuit, code, control, curcuit, error, f150, f250, ford, glow, module, p0675, plug, plugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
