wheelhop??
wheelhop??
hey guys, i have a 1993 ford f150 reg. cab long box with the 4.9l with a five speed. This is my first truck and i am 17 years old so of course i am experimenting with burnouts/powerbrakes hahaha. I have done three so far 2 of which were only one wheel spinning. But i was really surprised with the last one i did because it was full posi. What would make my truck lock into posi all of the sudden? Also when i first start out, i get alot of wheel hop. I know that this wheel hop is bad so i was wondering what causes it/ what i should do to prevent it?
I like this part of the advice. Buying traction bars for a pick up - 1 and to be able to spin the tires- 2 is retarded in my book. Not that I dislike a good burn out. But, a pick up truck spinning the tires is not impressive to me.
Your truck has an open differential, so the wheel that gets the least amount of traction will break loose and spin. If, by chance, both wheels happen to get the same amount of traction they will both spin, which does happen occasionally. I used to have a 302 powered Mustang II in high school which had an 8" open rearend. I installed some old slapper style traction bars and adjusted the snubbers so that the passenger's side would make contact first. With a little experimenting, I had it so that it would burn both back wheels 99% of the time.
The wheel hop is caused by the leaf spring wrap up and is very destructive to various components. Have fun while you can....when you get older you'll get tired of buying tires and fixing u-joints, clutches, brakes, etc.!
Lightning kemando... - YouTube
Aaron's Ford Lightning Burnout Number 1 - YouTube
But yes some long bars would be good. But if you just want to get rid of the wheel hop look into james duff bars. They are like $99 and stop the wheel hop. I have slapper bars and they work okay.
Your guys idea of a burn out is a lot different than mine , a burn out is just to get some heat in the tires before a race , just a few seconds on the brake then let the motor spin the tires out , so if you don't have a truck that will spin the tires with out the brake theres no point , to the OP , a good set of traction or ladder bars will take the spring wrap and wheel hop out , but a 4.9 is at the bottom of the bucket for performance so i don't see the point in it ....Lew
