2001 Navigator Transmission TCC issue
I have a 2001 Navigator 5.4L 4x4 that's throwing a P1744 code (Torque Converter Clutch System Stuck in Off Position) along with a flashing OD indicator on the shifter and the torque converter won't go into lock-up.
First off - do I have a 4R100 transmission in this truck?
Second - What can I do to isolate the problem without paying for a $2500 transmission rebuild? Based on some decent google-fu, I have a couple of ideas that I would like to put up for consideration:
1) Replace the TCC Solenoid.
- Can I replace just the solenoid, or do I have to replace the entire Solenoid Pack?
- How can I test the solenoid to see if it needs to be replaced?
- If I do this, then I would also replace the filter and flush the tranny.
2) Replace the Torque Converter.
- If the TCC solenoid doesn't correct the problem, is this the next option?
- I've never dropped a transmission, so not sure if I want to tackle this one.
3) Full transmission rebuild along with new Torque Converter, valve body, etc. Would like to avoid this costly repair if possible.
Thanks in advance for any input!
Fair enough. I'll have to do some more reading on the wiring harness issue. I remember reading a couple of things about it, but I need clarity regarding which harness, how to replace it, etc.
Mikey_23_ny1
10-02-2020 06:08 PM
