Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
WHAT HAVE YOU DONE TO YOUR TRUCK TODAY?
Old 09-06-2011, 08:10 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
(An excellent idea for any forum, that came from one of the older truck forums here!)
~I've been looking over the casting marks on two of my 351W's to determine how old they are, and anything I better know about external balancing...
Old 09-06-2011, 11:46 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Didnt do anything today. On Sunday my brother and I did a little panel weld and straighten.
This is before.
After
Back to work today after 3 day weekend.
Old 09-07-2011, 12:55 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
~I made my wallet $500 lighter (finally!). The necessaries from Advance Adapters are on the way - now I can get busy cleaning stuff up.
Old 09-08-2011, 09:08 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I used mine
My load bags were empty when I loaded so I took the truck to a gas station once full and filled up the bags. It was cool watching the truck rise like magic! Plus it handled it MUCH better!
Old 09-08-2011, 10:23 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
We used air shocks for that in the seventies -
Anyone remember "Gabriel Hyjackers"?
The cops would always let the air out if they could find the fill points - so you needed to hide them....
Got a race going on to see which of my parts come first - but that's little stuff
Old 09-09-2011, 02:48 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Had my fill valves inside the trunk area of my 66 chevell. Both on separte lines so I could offset the pressure for pounding the pavement. Just a little. Pounding the pavement that is.
Old 09-09-2011, 02:51 PM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
My buddy in high school ran his to right next to the drivers seat, and pulled the carpet over them. That way he had a quick way to let the air out when needed (on more than one occasion).
Old 09-12-2011, 05:26 PM
fordman75's Avatar
fordman75
fordman75 is offline
I had those "Gabriel Hyjackers" on my old 65 Mustang ( man I miss that car! ) . I raised some hell with that thing! I autographed plenty of intersections with my rear tires. That is until I snapped my transmission slip yoke into two pieces.
I haven't done a thing on my 54 in a long time. I've just been planning out my engine build and my little cab modification.
Old 09-12-2011, 06:18 PM
COMPLIT1107's Avatar
COMPLIT1107
COMPLIT1107 is offline
Had my Hijackers on a '67 chevelle. Remember adding air and standing back just to get the right "rake". What else could I do, It was a 6cyl/3spd (but it did have a 4bbl on an offenhauser !)
Learning how to weld panels and shrink dents on mine.....
Old 09-12-2011, 07:10 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
*If you think this thread is cool - rate it.
Good - bad, whatever....
I spun up the oil pressure in the 351W with a 5/16ths deepwell on a quarter drive extension , and using a drill. It almost fried my old B/D standby drill...
So I tried it by hand:
1) The oil pressure is solid, no binding as if stuff was broke
2) It seems to take a long time for the pressure to bleed down once it's run up
3) Main reason is to get a lubrication blanket everywhere before the engine is turned at all
4) Secondary purpose is to flush any condensation - but it was stored high up in a loft
It looks like it has a modded original strib - but THAT needs a closer look on the build thread.
Old 09-15-2011, 12:50 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Rattle Rattle Rattle..... painted a few more panels and dash pieces.
Old 09-15-2011, 09:15 AM
COMPLIT1107
and Weld, Weld, Grind, Grind..
Learning the hard way (experience, all by your lonesone) how to do patch panels...
Old 09-15-2011, 09:35 AM
Greywolf's Avatar
Greywolf
Greywolf is offline
I'm studyin' paint real close right now - I want the engine and trans to match the overall scheme and went to look at the source of a lot of trick paint (House of Kolor)
You can spend hours looking around the House of Kolor website......
House of Kolor (Parent company is VALSPAR)
THIS is the base color I chose - Kandy apple Cobalt Blue
Specifically: (pt#) HOK000538
You know my manic method by now - first I look to see if we have an FTE sponsor that supplies what I'm looking for, there are often discounts.
THEN I look outside of the box...
If I find a HIT; I track it to the source. Never deal with middle retailers, all that does is dilute your cashflow.
*I passed them on as a sponsor suggest - we really need a supplier/sponsor like this! RAW MATERIALS and bitchen ideas.....
Ken's74
20
08-15-2017 07:20 PM
fballguy
1999 to 2016 Super Duty
02-14-2016 06:10 PM
jrockdiddy
04-11-2014 04:48 PM
joeyd61
11-05-2013 09:36 PM
StatikPulse
51
04-14-2013 04:14 AM
Quick Reply: WHAT HAVE YOU DONE TO YOUR TRUCK TODAY?
