Fuel water separator draining - Ford Truck Enthusiasts Forums
Old 09-18-2011, 09:19 AM
p12483 p12483 is offline
p12483 is starting off with a positive reputation.
I am new to diesels as far as ownership. How often should I be draining my water separator. I have no indicator lights. Saw ricks trouble with possible warranty denial due to water in fuel so wanted to check and see. Only have 1100 miles and 3 fillups.
Old 09-18-2011, 09:33 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
It's recommended that you drain the fuel/water separator once a month to remove contaminants. See page 67 of your diesel supplement!
Old 09-18-2011, 10:57 AM
dschuffert's Avatar
dschuffert dschuffert is offline
dschuffert is gaining momentum as a positive member of FTE.dschuffert is gaining momentum as a positive member of FTE.
It is always a good practice to get into a preventive maintenance routine with these trucks. I go back to my old Army days where there was a specific routine for each piece of equipment before it was operated. I do the same with this truck and my farm equipment. Everyone is different and has their own way of doing things. At minimum, I recommend you follow the manual for the different maintenance tasks.
Old 09-18-2011, 03:07 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
I drain mine monthly.
The low cost of lost diesel is much cheaper than a new fuel system.
Old 09-18-2011, 03:10 PM
GCLL GCLL is offline
GCLL is gaining momentum as a positive member of FTE.
Doesn't the computer let you know when it needs drained?
Old 09-18-2011, 03:36 PM
Tom's Avatar
Quote:
There is a sensor, but you're still supposed to drain it monthly. If there is water sitting in the DFCM there is a higher likelihood that too much water will make it past the filter and into the high pressure fuel system. This can cause rust, pump failure, injector failure, and other very expensive problems. The 6.7L engine with it's Bosch system seems to be more resilient, but I wouldn't want to find out the hard way!
Old 09-19-2011, 06:01 AM
F2502011 F2502011 is offline
F2502011 is starting off with a positive reputation.
Glad I ran across this thread. Had the truck for 7 months and have never drained it didn't know it needed to be done so often and still wouldn't if I hadn't read this. Hopefully no damage has been done. Is it easy to do?
Old 09-19-2011, 06:06 AM
dschuffert's Avatar
Quote:
You should be fine. I drain mine monthly and have yet to see any water in it. I think it all depends on your fuel sources. The step-by-step instructions are in your manual, that is the best place to look before you do it the first time. Very simple to do.
Old 09-19-2011, 07:10 AM
Gunny77's Avatar
Gunny77 Gunny77 is offline
Gunny77 is starting off with a positive reputation.
This is good info, guess I need to drain mine. I assume that using a fuel additive like the motorcraft brand will help reduce the water.
Old 09-19-2011, 10:11 AM
kper05's Avatar
I was convinced early on to consider the WIF light to indicate an issue.
Ie; stop now and figure out why if it does turn on.
I've never had any water in my fuel but I wouldn't know that if I didn't drain it.
Old 09-19-2011, 10:24 AM
wtrlogd's Avatar
wtrlogd wtrlogd is offline
wtrlogd is gaining momentum as a positive member of FTE.wtrlogd is gaining momentum as a positive member of FTE.
Anyone know if draining water from the fuel separator is standard practice for a dealer while performing an oil change/service.
Old 09-19-2011, 10:47 AM
kabur66 kabur66 is offline
kabur66 is gaining momentum as a positive member of FTE.
I drained my separator for the first time. I drained it for about 25 seconds as recommendeds by the supplement. I really did not see any water (I don't think). The fluid must have been diesel fuel. How do you tell the difference between water and diesel fuel??? If I continued to drain the separator, will the fluid finally stop, or will it continue to drain diesel?
The diesel fuel is very pungent. Before my wife let me into the 5th wheel I had to change my closes and wash up.
ken
Old 09-19-2011, 10:50 AM
rickatic rickatic is offline
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
Quote:
It was not a standard practice at the dealer that I use...but it is now...the last 3 oil changes since I had the injector failure all received a water separator drain.
My truck gets drained every other tankful.
Regards
Old 09-19-2011, 10:55 AM
wiedsworld wiedsworld is offline
wiedsworld is starting off with a positive reputation.
ken
You will see water bubbles at the bottom of the container once you leave it settle for about 5 minutes. It's very easy to see water in fuel since it is heavier than the fuel and sits on the bottom. If you have a lot of it, you will see a clear cut line between the fuel and water. Hope this helps.
Old 09-19-2011, 02:27 PM
mach8274's Avatar
mach8274 mach8274 is offline
mach8274 is gaining momentum as a positive member of FTE.mach8274 is gaining momentum as a positive member of FTE.
Just drained mine about an hour ago...no water that I can see. Kinda makes one nervous though if we get bad fuel from a filling station.
WATER IN FUEL -- Fuel/water separator issue... dealership $$$ MudhenGIB 6.0L Power Stroke Diesel 20 05-11-2016 03:23 PM
water in fuel light goes on and off davbeisner 6.0L Power Stroke Diesel 26 07-27-2012 09:21 AM
Draining Water Separator marspec 6.4L Power Stroke Diesel 48 02-12-2012 12:05 PM
Fuel water separator wallyrock 1999 - 2003 7.3L Power Stroke Diesel 2 07-04-2009 07:02 PM
Draining Water Separator..Info Please fairhaven 6.4L Power Stroke Diesel 7 04-26-2009 05:58 PM
Tags
06, 2011, 2012, buy, chrome, deisel, differant, drain, draining, f250, f350, ford, fuel, plugs, separator, seperater, seperator, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
