clunking noise when turn and hit a bump - Ford Truck Enthusiasts Forums
Old 09-17-2011, 10:58 PM
built tough's Avatar
built tough built tough is offline
built tough is starting off with a positive reputation.
hey guys so i put a lift into my truck 4inch bds and 325/65/18 bfg a/t and theres a clunking noise coming from around under my feet now it does it when i turn either direction. I have noticed my tires are rubbing on my radius arms but not that bad so i dont think it could possibly be making that loud of a clunk. what else could it be steering stabalizer? it only does it every now and again so its hard to diagnose any help would be appreciated thanks
Old 09-18-2011, 01:13 AM
matty169 matty169 is offline
matty169 has a good reputation on FTE.matty169 has a good reputation on FTE.
try this.......
Disconnect your sway bar end links and drive. Your noise will almost certainly go away. Now, is it the end links or the sway bar bushings or both?
Old 09-18-2011, 08:28 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
Just a thought...u joints in the front axle?
Old 09-18-2011, 10:17 PM
Rossner's Avatar
Rossner Rossner is offline
Rossner is starting off with a positive reputation.
its the sway bar links, i had the same problem after putting a 4in lift on my truck.
Old 09-20-2011, 12:45 PM
beef producer beef producer is offline
beef producer is starting off with a positive reputation.
clunking on 2000 f250 7.3
After dropping the swaybar the noise was still there. We have finally traced the clucking on my 2000 f-250 to the rubber cab to frame mounts. There is one right under your left foot and a total of six in all. Two up front, one on either side where your feet are, and two on the back of the cab.
When the mechanic pulled them off the rubber had been pushed down and bulged out until the two metal pieces were bumping together. That was obvious because the metal has been peened over on the edges and was shiny.
Problem solved right? Not quite !!!! Ford says the number off my mount is actually for a f-550. NOT SO! I have two friends with similar trucks and the mount is the same on all 3. No big deal I'm not going to argue just send me a pair of f-550 mounts - right? Not so easy - Ford doesn't stock those mounts. They have to order them from the manufacturer. Now they say they say they can't get them.
As many entries as I see on this forum about clunking there must be some solution out there. I have seen aftermarket urethane mounts - is that the solution?
Old 09-21-2011, 12:39 PM
Bkiggins Bkiggins is offline
Bkiggins is starting off with a positive reputation.
Hey Beef Producer, Just seen your post and I had the same on my 07 PS and so I ordered the swaybar bushing kit and was getting to put the jack stands under the truck and I look up and there was a #2b stone stuck in the (Not sure what it is called but) the beam that bolts to the front axle to the frame about mid way under the front doors. Sorry for the poor discription but best I can do.
Old 09-21-2011, 01:20 PM
That is the area. It is surprising how much the cab of the truck moves up and down on the frame. These mounting blocks are definitely shot. They are supposed to be cylindrical but these are more like short fat exagerated barrels. The rubber does very little good. Mostly it is metal to metal and that is after 137K miles. I wonder about the guys with 300K miles.
I can't believe Ford doesn't stock them and can not get them from the manufacturer.
Old 09-22-2011, 12:59 PM
thanks guys just now getting around to it been very busy ill try to tighten up the sway bar bolts hard to see if the clunk is still there or not its ver speratic but its hunting season so im sure ill find it if its still there thanks
2004 navigator- kick into 4wd by itself? okiemike 1997-2006 Expedition & Navigator 1 07-28-2016 08:17 AM
Rearend Problems terrylamar 1978 - 1996 Big Bronco 8 07-20-2016 07:55 PM
Clunk Clunk Clunk noise on takeoff Aune163rd Modular V10 (6.8l) 6 08-15-2012 06:57 PM
clunk or bang noise in front end ? ? ? ? MiKeYs 2k DiEsEl 4x4 Excursion - King of SUVs 2 10-14-2008 06:27 PM
clunking/popping noise from front axle? 95f150 1987 - 1996 F150 & Larger F-Series Trucks 14 03-10-2004 07:01 PM
Tags
2005, 2006, 2007, bar, bump, bumps, clunk, escape, f150, f550, ford, front, hit, noise, torsion
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
