Oil Pressure Switch - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Oil Pressure Switch
Old 09-17-2011, 10:52 PM
Powermonger Powermonger is offline
Powermonger is starting off with a positive reputation.
Oil Pressure Switch
I need to locate my oil pressure switch and replace it. Can anyone tell me where to locate it?
Old 09-17-2011, 10:56 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
rite here ^^^^
Old 09-17-2011, 11:14 PM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputation
Post A tad mo info
Old 09-18-2011, 12:05 AM
joe_13894 joe_13894 is offline
joe_13894 is gaining momentum as a positive member of FTE.joe_13894 is gaining momentum as a positive member of FTE.
Better change yer HPOP oil
Old 09-18-2011, 12:12 AM
fordpride's Avatar
Quote:
Is that you Bill
Old 09-18-2011, 09:34 AM
Oil pressure switch
Quote:
Originally Posted by DRRXR View Post
my 95 PSDw/5spd is leaking oil, it is dripping almost running down the driver side, on the back side of the block, front of tranny.Not even possitive its the O.P.S but was told its located at the where the tranny and motor meet.
Old 09-18-2011, 10:17 AM
DRRXR's Avatar
Lets narrow down the leak.
Does the vally on top under the fuel bowl have oil in it. If not then check the turbo for oil leaks and the EBPV area. then repost...
Also the oil dipsticks have leaked at the attachment point so check that too.
Old 09-18-2011, 10:27 AM
O.P.S unit
I looked in the fuel bowl area and just checked around my turbo no leaks there?
Old 09-18-2011, 10:48 AM
DRRXR's Avatar
Well if its not the HPO line with a small pin hole the my guess would be the oil galley plug on the top rear of the engine. Those are a pain to remove. 1/2" Check the rear seal on the oil cooler too. You can see it by laying under the truck and its located just above the oil filter (kinda). If its the rear galley plug up top we can help you get to that too, hopefully with out stripping the head on it.
Old 09-18-2011, 11:04 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Old 09-18-2011, 11:11 AM
DRRXR's Avatar
NICEN DARIN
REAL NICEN
Old 09-18-2011, 12:28 PM
That sure is a pretty motor. Wish mine looked that nice. I stole that picture just like all the pictures I have..
Old 09-18-2011, 02:08 PM
Sorry, after further review it looks like the oil is leaking from a plate on the bottom of my transmission, "there's like a plate there and it looks like it is coming from inside of there, like its leaking from there" clearly, I'm confused. Need help.
Old 09-18-2011, 04:22 PM
I found the leak, back of drivers side valve cover, there is a half inch square that my half inch socket fits into and the whole thing looks like a cap, obviously I'm new at this, sorry. What is it? How do I fix it
Old 09-18-2011, 04:38 PM
Are you talking about one of those plugs in the picture I put up???? If not, I have no idea what you are referring to.
Oil pressure switch location on 1997 4.0? scooterspal Ranger & B-Series 3 09-14-2015 09:57 AM
'95 F150 351W Shows no oil pressure bennypapa 1987 - 1996 F150 & Larger F-Series Trucks 10 09-22-2013 02:59 PM
Oil Pressure Switch Location jcm46 6.4L Power Stroke Diesel 0 10-24-2008 08:28 PM
Explorer 2000 V8 oil pressure sensor location. andzia Explorer, Sport Trac, Mountaineer & Aviator 3 06-19-2007 11:32 PM
Oil Pressure Gauge Switch Jigsaw 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 3 10-30-2006 10:55 AM
Tags
2000, 2001, 42, 73, 73l, 97, f150, f250, f350, ford, high, location, oil, pressure, replace, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
